Results 1 to 7 of 7
    Full Member
    Jozef13's Computer Details
    Win 7
    HVAC
    AutoCAD 2016
    Jun 2015
    Slovakia
    33
    Default Dynamic Block Dependant Symetry
    Hello all,
    I have problem to keep dependant symmetry in my dynamic block of slot diffuser. I am not able to find where I made a mistake.
    Slot diffuser.jpgSlot diffuser.dwg
    Senior Member
    iconeo's Computer Details
    Windows
    Multi-disciplinary
    iconeo's Discipline Details
    CAD Manager/Draftsman
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    303
    It is because your move distance is currently tied to 'L' and not 'L2' I believe.
    Full Member
    Win 7
    HVAC
    AutoCAD 2016
    Jun 2015
    Slovakia
    33
    I have tried many combination, but without expected result
    Senior Member
    Windows
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    303
    Quote Originally Posted by Jozef13 View Post
    Try this.
    Slot diffuser.dwg
  5. #5
    Full Member
    Win 7
    HVAC
    AutoCAD 2016
    Jun 2015
    Slovakia
    33
    Symmetry is OK.
    But the size of diffuser "L" should be stretched just by one parameter (symmetricaly).
    "L1" parameter is just position of partition inside the diffuser and should not change the size of diffuser (L)
  6. #6
    Full Member
    Win 7
    HVAC
    AutoCAD 2016
    Jun 2015
    Slovakia
    33
    Hello,
    I have managed the expected result but only with using constraints.
    I am not able to find logic to do the same with parameters and actions tools.
    There is one thing with constraints that I would like to change and it is to set the full size of the diffuser.
    Currently I have to set half size (distance) as you can see in the picture because it keeps symetry around base point.
  7. #7
    Senior Member
    Windows
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    303
    I'm unclear as to what you are trying to do in this last step.
    Are you saying that if you stretch L you want the ratio between L1 and L2 to remain the same?
    Or do you want L1 or L2 to get longer?
    Are you supposed to be able to independently adjust L1 and L2?
    Thanks.
  1. LISP routine to insert a block at co-ords which are dwgname dependant
    By mitre962 in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Feb 2017, 12:29 pm
  2. templates difffer dependant upon how they are opened..
    By kippax in forum AutoCAD General
    Last Post: 18th May 2009, 09:46 am
  3. dependant parameters in dynamic blocks
    By Huibert in forum AutoCAD General
    Last Post: 8th Jul 2008, 03:52 pm
  4. Colour dependant to line weights
    By good_m in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Jun 2006, 01:50 pm
  5. Xref-dependant layer filter
    By Archteryx in forum AutoCAD General
    Last Post: 26th May 2005, 08:37 pm
