Results 1 to 5 of 5
    Forum Newbie
    Multi-disciplinary
    AutoCAD 2015
    Jan 2018
    2
    Default Create Lots of Rays
    Hello,
    I am using AutoCAD 2015. I am dummie in LISP. I need to creat a lot of rays. And I decided to optimize this process. BUT!
    When I use simple procedure right in command string:
    Code:
    Command: (command "RAY" "500,100" "400,500" "")
    RAY Specify start point: 500,100
    Specify through point: 400,500
    Command: nil
    AutoCAD drew ray with different coordinates:
    I don't understand: WTF?!
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,960
    Please do not add unrelated posts to threads.
    I have created you a new thread Create Lots of Rays in the AutoCAD 2D Drafting, Object Properties & Interface Forum.
    You probably don't need a LISP for this.
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,118
    I don't know lisp, but does your drawing contain other geometry close to those points, I know from working with scripts in LT that Autocad will still 'snap' to objects depending on zoom levels and you need to make allowances for that using the "non" command modifier before each coordinate, try your code in an empty drawing to see how that works.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
    Senior Member lrm's Avatar
    lrm's Computer Details
    Windows 7 64-bit
    16 GB
    Education
    lrm's Discipline Details
    Teacher, AEC and mechanical
    Education
    Civil and Mechanical
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    364
    The command:
    works for me. Make sure you do not have OSNAP on and that it's screwing things up! You can do it in vlisp with:
    (setvar "osmode" 0)
  5. #5
    Forum Newbie
    Multi-disciplinary
    AutoCAD 2015
    Jan 2018
    2
    Quote Originally Posted by lrm View Post
    The command:
    (setvar "osmode" 0)
    Yes, It works in a new file. I will add setvar in the command. After that I will report my result. Thx a lot!
  1. how to get the light rays for the lamp?
    By niegrau in forum Cameras, Lighting & Rendering
    Last Post: 12th Sep 2013, 05:44 pm
  2. Replies: 11
    Last Post: 20th Jun 2011, 03:52 pm
  3. How to find cross point when rays go through plane?
    By cnreader in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Mar 2009, 04:47 am
  4. Light rays through stained glass
    By lomaany in forum Cameras, Lighting & Rendering
    Last Post: 30th Dec 2008, 03:15 pm
  5. lots of visitors
    By Lazer in forum Autodesk Inventor
    Last Post: 23rd Jul 2007, 01:09 am
