Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
    Full Member
    Architecture 2016
    Nov 2014
    32
    Default HappyBirthday.lsp ==>Fun vs. prank
    Hi together,
    I would like to play a trick on my draftsman colleagues and I needed some help.
    ...feel free to improve my poor coding...
    Code:
    (defun c:HappyBirthday (/ UserName User1 B-Day_Date R-age age ry)
    	(if ;list of users for the pop-ups
    		(setq UserName (strcase(getvar 'loginname)))
    			(cond
    ;						User Name						User						Birthday						retirement age
    				((equal UserName "MH019") (setq User1 "Michael"		B-Day_Date "19991003"			R-age 67))
    				((equal UserName "MH019") (setq User1 "Michael"		B-Day_Date "20180109"			R-age 67))
    				((equal UserName "MH019") (setq User1 "Michael"		B-Day_Date "20180110"			R-age 67))
    				(T		(princ "\n\nSorry, User not listed !!!"))
    			);_cond end
    		);_progn end
    	);_if end
    	(setq age (itoa (- (atoi (substr (rtos (fix (getvar 'CDATE))) 1 4)) (atoi (substr B-Day_Date 1 4)) ) ));calculating the age of the user
    	(setq ry	(itoa (- R-age (atoi age))));remaining years until retirement
    	(alert
    		(strcat
    			"Hello " User1 "!"
    			"\n\nHerzlichen Glückwunsch zum " age ". Geburtstag !!!"
    			"\n\nCongratulations on your " age "st/nd/rd/ th birthday !!!" ;here I need some help for the e.g. 21st, 22nd, 23rd, 24th.
    			"\n\n\n\nVon jetzt an, sind es nur noch " ry " Jahre bis zur Rente \n... Also hau rein ... :-)"
    			"\n\nFrom now on, there are only " ry "  years left to retirement \n... so get in there ... :-)"
    			"\n\n\nKeyuser Michael"
    ;original code from 06.01.2011/Lee Mac changed on my needs
    ;http://www.cadtutor.net/forum/showthread.php?55800-Differences-in-exiting-AutoCAD&p=378358&viewfull=1#post378358
    (if
    	(not
    		(and
    			(setq date (getenv "OnceAYear"))
    			(< (fix (getvar 'CDATE)) (atoi date))
    		);_end and
    	);_end not
    		(c:HappyBirthday)
    		(setenv "OnceAYear" (itoa (+ 10000 (fix (getvar 'CDATE)))))	;stored in windows registry [HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.1\ACAD-D004:409\FixedProfile\General]
    	);_end progn
    );_end if
    Thank you in advanced !!!
    kind regards
    Bluebird1973
    Junior Member
    AutoCAD 2015
    Jun 2017
    19
    here's one way to get the suffix
    Code:
    (setq suffix (chr (last (vl-string->list age))))
    (cond ((eq suffix "1") (setq suffix "st"))
          ((eq suffix "2") (setq suffix "nd"))
          ((eq suffix "3") (setq suffix "rd"))
          ( T (setq suffix "th"))
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,405
    Quote Originally Posted by FranknBeans View Post
    Code:
    "13rd"
    Here's another possible way:
    Code:
    (defun ordinal ( n )
        (cond ((< 10 (rem n 100) 14) "th") ((nth (rem n 10) '(nil "st" "nd" "rd"))) ("th"))
    Code:
    _$ (ordinal 13)
    "th"
    _$ (ordinal 21)
    "st"
    _$ (ordinal 123)
    "rd"
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,405
    How about something like this?
    Code:
    (   (lambda ( lst / age itm ord ret )
            (defun ord ( n ) (cond ((< 10 (rem n 100) 14) "th") ((nth (rem n 10) '(nil "st" "nd" "rd"))) ("th")))
            (cond
                (   (null (setq itm (assoc (strcase (getvar 'loginname)) lst)))
                    (princ "\nSorry, user not listed!")
                (   (zerop (rem (setq age (- (fix (getvar 'cdate)) (caddr itm))) 10000))
                    (setq age (/ age 10000)
                          ret (- (cadddr itm) age)
                    (alert
                        (strcat
                            "Hello " (cadr itm) "!"
                            "\n\nHerzlichen Glückwunsch zum " (itoa age) ". Geburtstag !!!"
                            "\n\nCongratulations on your " (itoa age) (ord age) " Birthday !!!"
                            "\n\n\n\nVon jetzt an, sind es nur noch " (itoa ret) " Jahre bis zur Rente \n... Also hau rein ... :-)"
                            "\n\nFrom now on, there are only " (itoa ret) " years left to retirement \n... so get in there ... :-)"
            ("MH019" "Michael" 19991003 67)
            ("MH019" "Michael" 20180109 67)
            ("MH019" "Michael" 20180110 67)
    Copy the above into your acaddoc.lsp
  5. #5
    Junior Member
    AutoCAD 2015
    Jun 2017
    19
    Quote Originally Posted by Lee Mac View Post
    "13rd"
    oops
  6. #6
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,215
    This made me wonder, why not write some generic function that uses one of the arguments:
    '(day week month year)
    Code:
    (defun RunOnceA ( sym func ) ...)
    (RunOnceA 'week '(lambda ( / ) <bla-bla>) )
  7. #7
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,011
    Hellooooo
    make sure speaker is on
    Code:
    (defun SpeakSapi ( s / sapi )
        (if (eq (type s) 'STR)
            (setq sapi (vlax-create-object "Sapi.SpVoice"))
            (vlax-put sapi 'SynchronousSpeakTimeout 1)
            (vlax-invoke-method sapi 'WaitUntilDone 0)
            (vlax-invoke sapi "Speak" s 0)
            (vlax-release-object sapi)
    (speaksapi "please remain seated during your Autocad session do not leave work area")
    (setq x 24)
    (setq ans (strcat "alan is " (rtos x 2 0)))
    (speaksapi ans)
  8. #8
    Full Member
    Architecture 2016
    Nov 2014
    32
    Hi together,
    Thanks to everyone, I appreciate that very much !
    @ Lee Mac
    I didn't get your code to run. I put it on my acaddoc.lsp but nothing happens.
    What I'm doing wrong?
    ... and I have problems to understand what's going on. Could you please add some comments/explanations for me?
    Code:
            (cond
                    (alert
                        (strcat
    @BIGAL
    This is a funny one.... but we have no speakers ...
    Quote Originally Posted by BIGAL View Post
    Hellooooo
    Code:
    (setq x 24)
    (speaksapi ans)
  9. #9
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,405
    Quote Originally Posted by Bluebird1973 View Post
    @ Lee Mac
    It will only run when there is a birthday to be celebrated!
    Try adding a new user to the list whose birthday is today
  10. #10
    Full Member
    Architecture 2016
    Nov 2014
    32
    Thank you Lee Mac !!!
    now I got it. ...but didn't understand the code
    is there a way to not pank my draftsman the whole day?
    ... 3 or 4 times would be enough ...
  1. iPhone Photo Prank this Week
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 16th Jan 2015, 09:30 pm
