here's one way to get the suffix
Code:(setq suffix (chr (last (vl-string->list age)))) (cond ((eq suffix "1") (setq suffix "st")) ((eq suffix "2") (setq suffix "nd")) ((eq suffix "3") (setq suffix "rd")) ( T (setq suffix "th")) )
Hi together,
I would like to play a trick on my draftsman colleagues and I needed some help.
...feel free to improve my poor coding...
Thank you in advanced !!!Code:(defun c:HappyBirthday (/ UserName User1 B-Day_Date R-age age ry) (if ;list of users for the pop-ups (setq UserName (strcase(getvar 'loginname))) (progn (cond ; User Name User Birthday retirement age ((equal UserName "MH019") (setq User1 "Michael" B-Day_Date "19991003" R-age 67)) ((equal UserName "MH019") (setq User1 "Michael" B-Day_Date "20180109" R-age 67)) ((equal UserName "MH019") (setq User1 "Michael" B-Day_Date "20180110" R-age 67)) (T (princ "\n\nSorry, User not listed !!!")) );_cond end );_progn end );_if end (setq age (itoa (- (atoi (substr (rtos (fix (getvar 'CDATE))) 1 4)) (atoi (substr B-Day_Date 1 4)) ) ));calculating the age of the user (setq ry (itoa (- R-age (atoi age))));remaining years until retirement (alert (strcat "Hello " User1 "!" "\n\nHerzlichen Glückwunsch zum " age ". Geburtstag !!!" "\n\nCongratulations on your " age "st/nd/rd/ th birthday !!!" ;here I need some help for the e.g. 21st, 22nd, 23rd, 24th. "\n\n\n\nVon jetzt an, sind es nur noch " ry " Jahre bis zur Rente \n... Also hau rein ... :-)" "\n\nFrom now on, there are only " ry " years left to retirement \n... so get in there ... :-)" "\n\n\nKeyuser Michael" ) ) (princ) ) ;original code from 06.01.2011/Lee Mac changed on my needs ;http://www.cadtutor.net/forum/showthread.php?55800-Differences-in-exiting-AutoCAD&p=378358&viewfull=1#post378358 (if (not (and (setq date (getenv "OnceAYear")) (< (fix (getvar 'CDATE)) (atoi date)) );_end and );_end not (progn (c:HappyBirthday) (setenv "OnceAYear" (itoa (+ 10000 (fix (getvar 'CDATE))))) ;stored in windows registry [HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.1\ACAD-D004:409\FixedProfile\General] );_end progn );_end if (princ)
kind regards
Bluebird1973
Lee Mac Programming • Twitter • Exchange App Store • Dropbox (500MB free)
With Mathematics there is the possibility of perfect rigour, so why settle for less?
How about something like this?Copy the above into your acaddoc.lspCode:( (lambda ( lst / age itm ord ret ) (defun ord ( n ) (cond ((< 10 (rem n 100) 14) "th") ((nth (rem n 10) '(nil "st" "nd" "rd"))) ("th"))) (cond ( (null (setq itm (assoc (strcase (getvar 'loginname)) lst))) (princ "\nSorry, user not listed!") ) ( (zerop (rem (setq age (- (fix (getvar 'cdate)) (caddr itm))) 10000)) (setq age (/ age 10000) ret (- (cadddr itm) age) ) (alert (strcat "Hello " (cadr itm) "!" "\n\nHerzlichen Glückwunsch zum " (itoa age) ". Geburtstag !!!" "\n\nCongratulations on your " (itoa age) (ord age) " Birthday !!!" "\n\n\n\nVon jetzt an, sind es nur noch " (itoa ret) " Jahre bis zur Rente \n... Also hau rein ... :-)" "\n\nFrom now on, there are only " (itoa ret) " years left to retirement \n... so get in there ... :-)" "\n\n\nKeyuser Michael" ) ) ) ) (princ) ) '( ("MH019" "Michael" 19991003 67) ("MH019" "Michael" 20180109 67) ("MH019" "Michael" 20180110 67) ) )![]()
This made me wonder, why not write some generic function that uses one of the arguments:
'(day week month year)
Code:(defun RunOnceA ( sym func ) ...) (RunOnceA 'week '(lambda ( / ) <bla-bla>) )
Hellooooo
make sure speaker is on
Code:(defun SpeakSapi ( s / sapi ) (if (eq (type s) 'STR) (progn (setq sapi (vlax-create-object "Sapi.SpVoice")) (vlax-put sapi 'SynchronousSpeakTimeout 1) (vlax-invoke-method sapi 'WaitUntilDone 0) (vlax-invoke sapi "Speak" s 0) (vlax-release-object sapi) ) ) ) (speaksapi "please remain seated during your Autocad session do not leave work area") (setq x 24) (setq ans (strcat "alan is " (rtos x 2 0))) (speaksapi ans)
Hi together,
Thanks to everyone, I appreciate that very much !
@ Lee Mac
I didn't get your code to run. I put it on my acaddoc.lsp but nothing happens.
What I'm doing wrong?
... and I have problems to understand what's going on. Could you please add some comments/explanations for me?
@BIGAL
This is a funny one.... but we have no speakers ...
Thank you Lee Mac !!!
now I got it. ...but didn't understand the code
is there a way to not pank my draftsman the whole day?
... 3 or 4 times would be enough ...
