Great !!!
... but I would like to prank a little bit...
is it possible to add a counter which I could set to show up 3-4 times?
Something like this perhaps:
Code:( (lambda ( lst / age itm ord ret tmp ) (defun ord ( n ) (cond ((< 10 (rem n 100) 14) "th") ((nth (rem n 10) '(nil "st" "nd" "rd"))) ("th"))) (cond ( (null (setq itm (assoc (strcase (getvar 'loginname)) lst))) (princ "\nSorry, user not listed!") ) ( (and (zerop (rem (setq age (- (fix (getvar 'cdate)) (caddr itm))) 10000)) (or (null (setq tmp (getenv "CurrentAge"))) (/= age (atoi tmp)) ) ) (setenv "CurrentAge" (itoa age)) (setq age (/ age 10000) ret (- (cadddr itm) age) ) (alert (strcat "Hello " (cadr itm) "!" "\n\nHerzlichen Glückwunsch zum " (itoa age) ". Geburtstag !!!" "\n\nCongratulations on your " (itoa age) (ord age) " Birthday !!!" "\n\n\n\nVon jetzt an, sind es nur noch " (itoa ret) " Jahre bis zur Rente \n... Also hau rein ... :-)" "\n\nFrom now on, there are only " (itoa ret) " years left to retirement \n... so get in there ... :-)" "\n\n\nKeyuser Michael" ) ) ) ) (princ) ) '( ("MH019" "Michael" 19991003 67) ("MH019" "Michael" 20180109 67) ("MH019" "Michael" 20180110 67) ) )
Lee Mac Programming • Twitter • Exchange App Store • Dropbox (500MB free)
Great !!!
Code:; (RunOnceA 'day (lambda nil (alert "Hello world!"))) (defun RunOnceA ( sym func / env dateL tmp new old aL ) (defun SubstrByN ( n str ) (if (and (eq 'INT (type n)) (> n 0) (/= "" str)) (cons (substr str 1 n) (SubstrByN n (substr str (1+ n))))) ) (setq env "RunOnceA") (setq dateL (lambda nil (mapcar 'cons '(year month day) (apply '(lambda (a b c d) (list (strcat a b) c d)) (SubstrByN 2 (vl-prin1-to-string (fix (getvar 'cdate)))) ) ) ) ) (and ; first time using 'RunOnceA' function (or (= (setq tmp (getenv env)) "") (not tmp) ) (progn (setenv env (vl-prin1-to-string (dateL))) (func) ); progn ); and (if (member sym '(day month year)) ; check if valid symbol is provided, to avoid redundant prompts (if (not (equal (setq new (assoc sym (dateL))) (setq old (assoc sym (setq aL (read (getenv env))))) ) ) (progn (setenv env (vl-prin1-to-string (subst new old aL))) (func) ) ; first store the current date, incase (func) crashes (prompt (strcat "\nRunOnceA: will evaluate the next " (strcase (vl-prin1-to-string sym) t) ".")) ); if (prompt "\nRunOnceA: invalid symbol provided, use [day/month/year].") ); if ); defun RunOnceA
The following will 'prank' the user between 1 and 5 times if they 'roll a 3' when opening a drawing:
Code:;; Rand - Lee Mac ;; PRNG implementing a linear congruential generator with ;; parameters derived from the book 'Numerical Recipes' (defun LM:rand ( / a c m ) (setq m 4294967296.0 a 1664525.0 c 1013904223.0 $xn (rem (+ c (* a (cond ($xn) ((getvar 'date))))) m) ) (/ $xn m) ) ;; Random in Range - Lee Mac ;; Returns a pseudo-random integral number in a given range (inclusive) (defun LM:randrange ( a b ) (+ (min a b) (fix (* (LM:rand) (1+ (abs (- a b)))))) ) ( (lambda ( lst / age itm ord ret tmp ) (defun ord ( n ) (cond ((< 10 (rem n 100) 14) "th") ((nth (rem n 10) '(nil "st" "nd" "rd"))) ("th"))) (cond ( (null (setq itm (assoc (strcase (getvar 'loginname)) lst))) (princ "\nSorry, user not listed!") ) ( (and (zerop (rem (setq age (- (fix (getvar 'cdate)) (caddr itm))) 10000)) (= 3 (LM:randrange 1 6)) ;; Adding some randomness to when the message is displayed (cond ( (or (null (setq tmp (getenv "CurrentAge"))) (< (atoi tmp) age)) (setenv "CurrentAge" (itoa (+ age (LM:randrange 1 5)))) ) ( (< age (atoi tmp)) (setenv "CurrentAge" (itoa (1- (atoi tmp)))) ) ) ) (setq age (/ age 10000) ret (- (cadddr itm) age) ) (alert (strcat "Hello " (cadr itm) "!" "\n\nHerzlichen Glückwunsch zum " (itoa age) ". Geburtstag !!!" "\n\nCongratulations on your " (itoa age) (ord age) " Birthday !!!" "\n\n\n\nVon jetzt an, sind es nur noch " (itoa ret) " Jahre bis zur Rente \n... Also hau rein ... :-)" "\n\nFrom now on, there are only " (itoa ret) " years left to retirement \n... so get in there ... :-)" "\n\n\nKeyuser Michael" ) ) ) ) (princ) ) '( ("MH019" "Michael" 19991003 67) ("MH019" "Michael" 20180109 67) ("MH019" "Michael" 20180110 67) ) ) (princ)
Well thank you Lee![]()
Just imagine Lee's code triggering some Sapi voices randomly!![]()
Most people here have muted their pc but the colleague right in front of me hasn't ... he would make a good candidate. In fact , I have 'pranked' him in the past. He likes to kill rabbits in his spare time so one day I arranged for a slide to appear with each drawing he opened with a armed rabbit showing![]()
