Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Forum Newbie
    Construction
    AutoCAD 2017
    Jan 2018
    9
    Exclamation Lisp routine to clean up architects layout
    Hi need help with a lisp routine to clean up architects drawings with the following.
    Unlock,Unfreeze & turn on all layers
    Burst
    Change all layers to bylayer
    Change all hatch’s to colour 254 and send to back
    Change all line weights to 0.18
    Change all to Colour 8
    Overkill
    Purge
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,011
    A couple of questions
    The layers set to bylayer or all objects bylayer also ? If all by layer then set the line weight as part of change layer settings same as colour.
    Code:
    (defun allbylayer ( / x obj ssall)
    (setq ssall (ssget "x"))
    (repeat (setq x  (sslength ssall))
    (setq obj (vlax-ename->vla-object (ssname ssall (setq x (- x 1)))))
    (vlax-put-property obj "Linetype" "Bylayer")
    (vlax-put-property obj "Lineweight" " -1")
    (vlax-put-property obj "Color" acbylayer)
    (allbylayer)
    (Alert "All objects now by layer")
    Code:
    ; open database
    (setq  doc (vla-get-activedocument  (vlax-get-acad-object)))
    (setq lays (vla-get-Layers doc))
    (vlax-for lay lays
    (vla-put-color lay 8)
    (vla-put-lineweight lay 18) ; note 18 for metric =0.18 not tested on feet dwg must match a known size.
    Burst has an alias when used with lisp will find. But this works
    Code:
    (while (setq ss (ssget "X" ))
    (sssetfirst nil ss)
    (C:Burst)
    Purge use
    Code:
    (command "-purge" "all" "*" "n")
    Overkill help anyone
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,084
    I could do with a LISP that would work on the Architect's before they start on the drawings
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
    Forum Newbie
    Construction
    AutoCAD 2017
    Jan 2018
    9
    Thanks BIGAL will give it a go & let you know how it goes!
  5. #5
    Forum Newbie
    Construction
    AutoCAD 2017
    Jan 2018
    9
    BIGAL yes all layers changed to bylayer & all to colour 8, also any joy with the hatch to 254 & set to back?
  6. #6
    Forum Newbie
    Construction
    AutoCAD 2017
    Jan 2018
    9
  7. #7
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    594
    THIS could be modified to do what you want.
  8. #8
    Forum Newbie
    Construction
    AutoCAD 2017
    Jan 2018
    9
    Thanks could you send a lsp for me to try?
  9. #9
    Super Member
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    594
    Quote Originally Posted by ronjonp View Post
    Here's a start:
    Burst
    Change all layers to bylayer Assume this is all objects to bylayer
    Overkill
    Purge
    Code:
    (defun c:drawingtobylayer
           ;;  Copyright © 2004 Michael Puckett. All Rights Reserved
           ;;  Forces the entire drawing to "ByLayer" (even xrefs for
           ;;  the lifetime of the session or until an xref reload
           ;;  occurs).
           ;;  Forces block definition child entities to layer "0".
           ;;  Existing attributes are forced to the same layer the
           ;;  parent block reside on.
           ;;  Nominally tested, let me know if you find anything wonky.
           ;;  * Use at your own risk. Please test on a dummy dwg *
           (/ _unlockalllayers _locklayers _objecttolayerzero _objecttobylayer _documenttobylayer _main)
      ;; (idt_draworder (idt_ss->vla-list (ssget)) 'movetobottom)
      (defun _unlockalllayers (document / result)
        (vlax-for layer (vlax-get-property document 'layers)
          (cond ((eq :vlax-true (vlax-get-property layer 'lock))
    	     (vlax-put-property layer 'lock :vlax-false)
    	     (setq result (cons layer result))
          ;; RJP added: Change all layers to color 8, linewight to 18mm, thaw and turn on
          (foreach property	'((color . 8) (lineweight . 18) (freeze . 0) (layeron . -1))
    	(vl-catch-all-apply 'vlax-put (list layer (car property) (cdr property)))
        result
      (vlax-ename->vla-object (tblobjname "layer" "0"))
      (defun _locklayers (layers) (foreach layer layers (vlax-put-property layer 'lock :vlax-true)))
      ;; (defun _objecttolayerzero (object) (vlax-put-property object 'layer "0"))
      (defun _objecttobylayer (obj / layer)
        ;; RJP added lineweight and transparency
        (foreach property '((color . 256)
    			(linetype . "ByLayer")
    			(lineweight . "ByLayer")
    			(transparency . "ByLayer")
          (vl-catch-all-apply 'vlax-put (list obj (car property) (cdr property)))
        (cond ((and	(eq "AcDbBlockReference" (vlax-get obj 'objectname))
    		(eq :vlax-true (vlax-get-property obj 'hasattributes))
    	   (setq layer (vlax-get-property obj 'layer))
    	   (foreach child (vlax-invoke obj 'getattributes)
    	     (_objecttobylayer child)
    	     (vlax-put-property child 'layer layer)
    	  ;; RJP added hatch to color 254
    	  ((eq "AcDbHatch" (vlax-get obj 'objectname))
    	   (vl-catch-all-apply 'vla-put-color (list obj 254))
      (defun _documenttobylayer (document)
        (vlax-for block (vlax-get-property document 'blocks)
          (if (eq :vlax-true (vlax-get-property block 'islayout))
    	(vlax-for object block (_objecttobylayer object))
      (defun _main (/ document lockedlayers)
        (setq lockedlayers
    	   (_unlockalllayers
    	     (setq document (vlax-get-property (vlax-get-acad-object) 'activedocument))
        (_documenttobylayer document)
        ;; RJP leave layers unlocked
        ;; (_locklayers lockedlayers)
      (_main)
  10. #10
    Forum Newbie
    Construction
    AutoCAD 2017
    Jan 2018
    9
    Thanks Ronjonp will give this a try!
  1. LISP | Clean Drawing | Explode and Purge
    By bluebravo in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Aug 2017, 04:25 am
  2. Lisp routine for Rebar Layout
    By guyzen2004 in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th May 2014, 06:08 am
  3. Lisp to clean files
    By NineteenHand in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jan 2014, 09:14 pm
  4. Lisp routine to print layout tabs and exclude model tab
    By jason_a in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Nov 2010, 08:28 pm
  5. Architectural Clean Up Routine?
    By thedissident001 in forum CAD Management
    Last Post: 14th Sep 2010, 12:16 pm
Tags for this Thread
