Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Super Member
    Dipali's Computer Details
    windows 10
    TOSHIBA "SATELLITE"
    Intel inside CORE i7
    viewsonicVA1916w
    Architectural
    Dipali's Discipline Details
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2015
    Dec 2007
    INDIA
    1,106
    Unhappy auto cad stopped loading
    while i was away from my desk last Saturday, in my laptop, some updates happened on Windows 10.
    since then my auotcad has stopped working. when i start an application, at first it starts to load but then it gives me the message as below.
    "AutoCAD Application has stopped working
    A problem has caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
    yesterday, my husband(IT person) rolled back the update also but still the problem is not solved.
    any suggestions
    "An architect's most useful tools are an eraser at the drawing board & a wrecking bar at the site."
    Frank Lloyd Wright
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,960
    Are you using AutoCAD 2015?
    Super Member
    windows 10
    TOSHIBA "SATELLITE"
    viewsonicVA1916w
    Architectural
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2015
    Dec 2007
    INDIA
    1,106
    yes it is part of building design suit 2015.
    I normally use auto cad only, but after the problem started i tried other applications and all AutoCAD applications are giving me same errors.
    but i tried Revit now and it is working.
    Frank Lloyd Wright
    Full Member Incognito Cube's Avatar
    Incognito Cube's Computer Details
    Windows 10 Pro
    Dell Precision T1700
    Intel(R) Xeon(R) CPU E3-1225 v3 @ 3.20GHz
    8Gb DDR3
    #1: Intel(R) HD Graphics P4600/P4700 #2: NVIDIA Quadro K620
    WDC WD5000AAKX-75U6A SCSI
    x2 Dell E2011H
    Surveying
    Incognito Cube's Discipline Details
    Platting Technician
    Surveying
    ALTA Surveys, Mortgage Surveys (Plot Plans, Finals, etc.), Plats, Boundary/TOPOs.
    Civil 3D 2014
    Jan 2018
    Orlando, Florida
    38
    The Autodesk Knowledge Network states "This is due to an issue with the Microsoft .NET Framework" and lists a solution as:
    "The .NET Framework 4.7.1 was released on October 17, 2017. Based on feedback recently received, this update has resolved the issue for some where we’ve been seeing with AutoCAD software breaking on Windows 7-10 with the .NET 4.7 install. The same update is included in the Windows 10 Fall Creators Update."
    So, if you can, check to see if you are the most up-to-date that you can be with your framework. Just in case, attempt to reinstall them directly from Microsoft as something may have gone wrong during the original update, and may not have been repaired with a restore.
    Alternatively, it appears the only other suggested solution (That you haven't listed you doing yet) is:
    "The Creators Update includes Windows Defender (antivirus software) which may be the root cause. Add an exclusion to Defender for all Autodesk software folders"
    Hopefully this helps! Let us know!
  5. #5
    Super Member
    windows 10
    TOSHIBA "SATELLITE"
    viewsonicVA1916w
    Architectural
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2015
    Dec 2007
    INDIA
    1,106
    Thanks, I checked with my IT guy and he has tried it all which is suggested above.
    Any other suggestions.
    Frank Lloyd Wright
  6. #6
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    Have you tried a REPAIR of the installation?
  7. #7
    Super Member
    windows 10
    TOSHIBA "SATELLITE"
    viewsonicVA1916w
    Architectural
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2015
    Dec 2007
    INDIA
    1,106
    Yes, we did. Didn't helped.
    Frank Lloyd Wright
  8. #8
    Windows 10 Pro
    8Gb DDR3
    x2 Dell E2011H
    Surveying
    Platting Technician
    Surveying
    Civil 3D 2014
    Jan 2018
    Orlando, Florida
    38
    Well, let's try something here. Might be a crap-shoot, but there's not much better to do while we wait for/find a solution. Download the trial version of 2018 Cad from Autodesk's site, and see if you can run that.
    Marginally smarter than a white person in an infomercial.
  9. #9
    Super Member
    windows 10
    TOSHIBA "SATELLITE"
    viewsonicVA1916w
    Architectural
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2015
    Dec 2007
    INDIA
    1,106
    Sorry we had gone to sleep, as it was night for us.
    aperantly he was not able to run repair, as he needed a installer for that and this was online installation, so he was looking for option.
    Now in the morning, he looked at few things, and he is thinking that some update was happening on autocad, which may got aborted due to shutdown in. Y absence, and so now he is running that update. So it will take about 4 hours.
    I will post the result once I come to know.
    Frank Lloyd Wright
  10. #10
    Super Member
    windows 10
    TOSHIBA "SATELLITE"
    viewsonicVA1916w
    Architectural
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2015
    Dec 2007
    INDIA
    1,106
    that didn't work. then he found installer pen drive. so we reinstalled it. b
    but still same problem. so it looks like it is windows issue. so he will have to do system repair and it will take time.
    meanwhile Revit is working, but i have not worked in it much, so can't do much.
    So i have to do some documentary work which i will continue on this and will use one of the staff computer for cad work. in the weekend i will give him my laptop for system repair
    Frank Lloyd Wright
  1. Sheet Set not auto loading in sheet set manger when opening drawing.
    By Tudors in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Dec 2017, 02:04 am
  2. Replies: 7
    Last Post: 25th Feb 2017, 01:44 am
  3. Macros Have Stopped Working
    By resullins in forum AutoCAD General
    Last Post: 1st Apr 2014, 05:07 pm
  4. xattach stopped working
    By toberino in forum AutoCAD Drawing Management & Output
    Last Post: 14th Nov 2012, 08:55 pm
  5. Autocad 2009 auto loading Raster design 2009
    By spinnerbayt in forum AutoCAD General
    Last Post: 24th Sep 2009, 12:54 pm
