Results 1 to 6 of 6
    Full Member
    Mechanical 2013
    Aug 2010
    40
    Default Diameter symbol in MTEXT
    Our office has been using the archquik.shx font forever. One thing that always bothered me is that when using MTEXT I cannot get a diameter symbol.
    I can type the symbol by pressing (ALT+0216), but the diameter symbol changes to another font, Arial in this case.
    If I use the the symbol option while within the 'Text Formatting' window of MTEXT, I get the symbol, but again it changes font style to ISOCPEUR.
    In either of the above scenarios I cannot then change the symbol to the archquik font.
    See the screenshots as an example.
    However, if i use the single line text command, I can type %%129 and get the symbol in the archquik font. Therefore, it is supported within archquik, but not when using MTEXT.
    Is there anyway to get MTEXT to recognize the diameter symbol in archquik? And if so, is there a shortcut keystroke that can be incorporated similar to the ALT+0216 that I mentioned earlier?
    Full Member Incognito Cube's Avatar
    Incognito Cube's Computer Details
    Windows 10 Pro
    Dell Precision T1700
    Intel(R) Xeon(R) CPU E3-1225 v3 @ 3.20GHz
    8Gb DDR3
    #1: Intel(R) HD Graphics P4600/P4700 #2: NVIDIA Quadro K620
    WDC WD5000AAKX-75U6A SCSI
    x2 Dell E2011H
    Surveying
    Incognito Cube's Discipline Details
    Platting Technician
    Surveying
    ALTA Surveys, Mortgage Surveys (Plot Plans, Finals, etc.), Plats, Boundary/TOPOs.
    Civil 3D 2014
    Jan 2018
    Orlando, Florida
    38
    MText, from what I understand, uses a different coding than regular TEXT or DTEXT to pull symbols into strings of text. Some of the time, the font versions that Autodesk uses and deploys in their products are from before 2004, so they aren't Unicode and thus, MTEXT can't utilize them. Therefore, in order to get the symbols you need in MTEXT you must have the newest (Unicode) version of a font, or, use another font altogether. Ex. using romanS instead of roman.. ISCPEUR seems to be the go-to used by CAD to replace lost/missing symbols when it comes to some font types.
    Someone correct me if I'm wrong?
    Marginally smarter than a white person in an infomercial.
    Full Member
    Mechanical 2013
    Aug 2010
    40
    Seems correct to me. In my online search an updated unicode version of archquik.shx was mentioned. It was called archqwiku.shx. However, the site referenced to download it from no longer exists. If anyone has a reliable source for Unicode fonts please let me know. In the meantime I will continue to search. Thanks!
    Windows 10 Pro
    8Gb DDR3
    x2 Dell E2011H
    Surveying
    Platting Technician
    Surveying
    Civil 3D 2014
    Jan 2018
    Orlando, Florida
    38
    After a 5-10 min search, I couldn't find anything for a DL for that specific font. However, I did find this in my virtual travels:
    http://www.high-logic.com/font-editor/fontcreator.html
    Might be worth investigating and possibly using the free trial if you're desperate to get the consistency you're looking for. Apparently with this program you can load a font file, and add/edit characters to make new ones in the UNICODE format. So, who knows? You might end up learning the basics to creating fonts ͡° ͜ʖ ͡°
    Though, I'm unsure about the limitations that may be imposed with the trial version & I know my company's IT dept wouldn't just let me willy-nilly DL a new program like that.
    Last edited by Incognito Cube; 10th Jan 2018 at 06:20 pm. Reason: Grammar, again..
  5. #5
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,154
    To get a diameter sign in ARCHQUICK font, use the unicode string \U+0081
  6. #6
    Full Member
    Mechanical 2013
    Aug 2010
    40
    Quote Originally Posted by eldon View Post
    Excellent. Is there a way to include that specific code on the symbol list (third screenshot on my initial post)?
  1. diameter symbol
    By Thomas Baxter in forum AutoCAD LT
    Last Post: 26th Nov 2017, 05:12 pm
  2. How to remove the diameter symbol?
    By GeeN in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Jan 2015, 12:48 am
  3. Diameter Symbol In Arial Font
    By RobDraw in forum CAD Management
    Last Post: 24th Sep 2014, 01:39 pm
  4. Diameter symbol for Excel export
    By MSasu in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Sep 2011, 07:54 am
