Layouts - vlax-for and vla-get-layouts
abra-CAD-abra
All,
In AutoCAD 2016, and when using vlax-for and vla-get-layouts in the code below, I need to switch to a different layout before the new layout names are applied to the layouts.
(defun C:DEMO (/ tab str)
 (vl-load-com)
 (vlax-for lyt (vla-get-layouts
   (vla-get-activedocument (vlax-get-acad-object))
   (setq tab (vla-get-name lyt))
   (setq str (substr tab 1 4))
   (vla-put-name lyt (strcat "2" str))
Any ideas?
Thanks
error: Automation Error. Cannot rename the Model layout need a IF to check tab is not Model
 (vl-load-com)
   (If (/= "Model" tab)
(c:demo)
 (vl-load-com)
(c:demo)
Thanks BIGAL,
Fixed it.
SUBSTR starts at 1, not 0 as with other functions like NTH.
(defun C:DEMOX (/ tab str)
 (vl-load-com)
   (setq str (substr tab 2 5))
   (if (not (eq "MODEL" (strcase (vla-get-name lyt))))
Appreciate your help
