Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 24
  1. #11
    Junior Member
    Civil
    AutoCAD LT 2018
    Nov 2017
    14
    I've actually got one more question if that's ok yall!
    [IMG][/IMG]
    As per the image above, if you wanted to fillet an arc between the cyan and magenta lines, the cyan being an arc and the magenta being a straight, is it possible to get an arc in there that will have its end point at the end of the magenta line? I would like that point to be the tangent point for the arc. Ive tried guessing radiuses, and I tried a circle TTR which worked I think, but I couldn't trim the circle as I was getting the "does not intersect at 2 points' message.
    Thanks everyone!
  2. #12
    Junior Member
    Civil
    AutoCAD LT 2018
    Nov 2017
    14
    Btw I hope that's clear enough which lines I'm referring to....I've highlted them and their end points are showing.
  3. #13
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,105
    I would construct the arc. There may be an automatic way of doing things.
    First of all, draw a line from the centre of the arc to its end point. Then draw the tangent to intersect with the magenta line (it is very easy to draw lines at 90° when Polar tracking is in action). Now draw the angle bisector between these two lines (blue line). Now project your first line to intersect this angle bisector line. Where they cross is the centre of the arc.
    Kerb nosings are sometimes precast in 90° sections, so the actual junctions with the straights can be a bit of a bodge.
  4. #14
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,105
    The way I construct an angle bisector is to draw a circle centred at the intersection point. Then trim this circle with the tangents. Then draw a line from the intersection point to the mid point of the arc. This is the angle bisector.
  5. #15
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,175
    Re kerb radius it can go as low as zero for back to back if your lip is 0.6m rad with a 0.3m kerb then radius is zero. Often the ped walk is cut at 90 so kerb goes around again rad is zero with a 45 mitre.
  6. #16
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,175
    Given the two point options Eldon your answer is correct for matching the arc end point draw a line from end to center point then the circle tangent length then a 90 line from the line point gives the new center.
    To match a known point is a bit harder and may require an iteration to keep filleting till end point matches the point co-ords. There is a mathematical answer and its inside surveyors reverse curve formulas, the one required is for non parallel lines. Its something that is on my wish list to do as its a pain in Autocad to do reverse curves very quickly. Not at work else would post diagram.
    For parallel then variables are R1 R2 offset and distance between ends or combinations of known solving the unknown. These are fairly simple mathematical formulas.
  7. #17
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,105
    I see that my solution only uses the end of the arc as a fixed point, but not the end of the straight. So the end of the straight is wherever the arc ends.
    My feeling is that it is not possible geometrically to join your two fixed points with an arc being tangential at each fixed point. You need a transition curve of varying radius. Or you could draw a polyline and give it tangential directions at each end.
  8. #18
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,175
    Your correct Eldon it comes down to picking a radius, or which point to match to. The attached is the formula for reverse curves.
  9. #19
    Junior Member
    Civil
    AutoCAD LT 2018
    Nov 2017
    14
    Thanks guys for sharing your thoughts, appreciate it. I never gave arcs and curves much thought, ran away from them, but understanding them is so important for horizontal geometry!
  10. #20
    Junior Member
    Civil
    AutoCAD LT 2018
    Nov 2017
    14
    so i'm back playing with arcs again, and noticed that when i was trying to fit an arc between a straight and an arc, the fillet command would produce an error of "cannot fillet between these two entitites".
    It is an arc and a polyline in question, with z values at 0, and i have set a radius i wish to achieve for the fillet command.
    Then i tried the Circle, Tangent command and it does seem to produce a circle that fits at the desired radius.
    Why would the fillet command not work yet the circle command seems to achieve what i am after? Or is the arc from the Circle command not going to be quiet right?
    Thanks again everyone!
  1. On error checking...
    By LosGirk in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd May 2014, 09:48 pm
  2. Clearance checking?
    By Sophisto in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Jun 2010, 08:14 pm
  3. Region checking
    By AcmeMan in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Dec 2006, 10:40 am
  4. checking the polylines
    By vivekgrs in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Sep 2006, 05:12 am
