Results 1 to 9 of 9
    Junior Member
    AutoCAD 2017
    Oct 2017
    19
    Default How to draw a specific angle from a tangent?
    In the attachment, it can be seen in the first screen shot that I have drawn a line from the quadrant of the circle at an of 72 degrees.
    However it can be seen from the second screen shot that when I try to draw an angle from the tangent it doesn't provide the facility to enter the angle in a box.
    Is this not an option from the tangent?
    Full Member Incognito Cube's Avatar
    Incognito Cube's Computer Details
    Windows 10 Pro
    Dell Precision T1700
    Intel(R) Xeon(R) CPU E3-1225 v3 @ 3.20GHz
    8Gb DDR3
    #1: Intel(R) HD Graphics P4600/P4700 #2: NVIDIA Quadro K620
    WDC WD5000AAKX-75U6A SCSI
    x2 Dell E2011H
    Surveying
    Incognito Cube's Discipline Details
    Platting Technician
    Surveying
    ALTA Surveys, Mortgage Surveys (Plot Plans, Finals, etc.), Plats, Boundary/TOPOs.
    Civil 3D 2014
    Jan 2018
    Orlando, Florida
    38
    I've only been familiar with drawing tangents for a few months now, but wouldn't the angle of the line change the point where the line creates a tangent connection? Rendering the ability to change it's angle pointless if you're trying to keep the line/curve tangent?
    Marginally smarter than a white person in an infomercial.
    Windows 10 Pro
    8Gb DDR3
    x2 Dell E2011H
    Surveying
    Platting Technician
    Surveying
    Civil 3D 2014
    Jan 2018
    Orlando, Florida
    38
    I'm pretty sure, in this case, you'd have to use the rotate command with the centerpoint of the circle as your base point in order to change the angle of that line and keep it tangent, yeah?
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,144
    Yeah, a tangent is always 90 degrees, If you try and alter it from that point then it is by definition no longer a tangent, and if you which to adjust the line from its free end then the tangent point will move, but always be 90 degrees. So yes the answer is it's not an option
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  5. #5
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    HP ZBook 17
    i7-4810MQ @ 2.80 GHZ
    16GB
    Nvidia Quadro K4100M
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    rkmcswain's Discipline Details
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,508
    If you type in the old way, starting with the "@" character, then you can enter a distance (say 190), then type in the ">" character, and it will allow you to enter the angle (say 45°)
    If you turn off the on screen prompts and do it at the command line, the syntax is "@190.0<45"
    R.K. McSwain
    CAD Panacea | twitter
  6. #6
    Junior Member
    AutoCAD 2017
    Oct 2017
    19
    Smile
    Thanks very much for the replies - much appreciated.
    What I'm trying to do, and am having some difficulty with, is to draw the radius 5 circle at the bottom of the image then draw a line at an angle of 85 degrees.
    Another radius 5 circle has a vertical distance of 42 units above.
    Is it possible to do this whilst connecting the two circles via their tangents, not their quadrants?
  7. #7
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,399
    Line tan 1st circle tan 2nd circle.
    Draw a line at 85 from the centre of the 1st circle then draw a horizontal line 42 above this is center of second circle where they cross.
  8. #8
    Junior Member
    AutoCAD 2017
    Oct 2017
    19
    Quote Originally Posted by BIGAL View Post
    How do I "line tan" and "tan" the circles?
  9. #9
    Junior Member
    AutoCAD 2017
    Oct 2017
    19
    I think I've been able to do that now.
    I've drawn the lower rad5 circle.
    Drew a longer than required line at angle of 85 from centre of this circle.
    Drew a vertical line from centre of first circle down to its circumference.
    Drew a horizontal line across to the right.
    Drew a line of 42 vertically upwards.
    Drew a line left until it intersected the diagonal line.
    Drew 2nd circle centred on this intersection.
    Finally drew a line from tangent to tangent.
  1. set angle tangent of polyline vertex
    By motee-z in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Jun 2015, 12:18 am
  2. Replies: 3
    Last Post: 4th Sep 2014, 05:33 pm
  3. How do i draw line at specific angle?
    By nbaryosef in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Jan 2013, 07:54 pm
  4. How to specify a tangent line at an angle
    By deangelis in forum AutoCAD General
    Last Post: 22nd Sep 2010, 04:23 pm
  5. How to draw a cylinder at a specific angle
    By cruzersoul in forum AutoCAD 3D Modelling & Rendering
    Last Post: 1st May 2009, 01:55 pm
