Reset one instance of a block and it's attributes to the defaults of that block
mk4176
Hello,
Using the sync attributes (attsync), resets all the attributes properties of all occurrences of that block in the drawing to the defaults.
Anyone has a lisp that will reset all properties of one instance of a block to the default properties including attributes?
Only the picked instance or several occurrence picked should be reset by the lisp.
Thank you
Reinserting will ruin the values of the attributes.
I need to reset the only the properties to default.
Like the rotation, Height, visibility and so on.
Regards
Heres one reinserting approach:
(defun C:test ( / SS spc i nm e1 o1 enx1 e2 o2 enx2 L blks )
 (and
   (princ "\nSelect Attributed blocks: ")
   (setq SS (ssget "_:L" '((0 . "INSERT")(66 . 1))))
   (setq spc (getvar 'ctab))
   (repeat (setq i (sslength SS))
     (and
       (setq o1 (vlax-ename->vla-object (setq e1 (ssname SS (setq i (1- i))))))
       (VanillaINSERT (vlax-get o1 'InsertionPoint) (setq nm (vlax-get o1 'EffectiveName)) spc)
         (foreach x
           (mapcar 'list
             (vlax-invoke o1 'GetAttributes)
             (vlax-invoke (setq o2 (vlax-ename->vla-object (setq e2 (entlast)))) 'GetAttributes)
           (apply (function (lambda (a b) (vla-put-TextString b (vla-get-TextString a)))) x)
         (mapcar 'set '(enx1 enx2) (mapcar 'entget (list e1 e2)))
         (foreach x '(8 41 42 43 50)
           (setq enx2 (subst (assoc x enx1) (assoc x enx2) enx2))
         (entmod enx2)
         (and
           (eq (vla-get-IsDynamicBLock o1) :vlax-true)
           (setq L (vlax-invoke o1 'GetDynamicBlockProperties))
           (foreach x (mapcar 'list L (vlax-invoke o2 'GetDynamicBlockProperties))
             (vl-catch-all-apply
               (function
                 (lambda (a b)
                   (vla-put-Value b (vla-get-Value a))
                 ); lambda
               ); function
               x
           ); foreach
         ); and
         (entdel e1) (setq blks (cons (if (not (member nm blks)) nm) blks)) T
       ); progn
     ); and
   ); repeat
   (and (setq blks (vl-remove 'nil blks))
     (setvar 'cmdecho 0)
     (foreach x (vl-remove 'nil blks) (command "_.ATTSYNC" "_N" x) )
     (setvar 'cmdecho 1)
 ); and
); defun
(vl-load-com) (princ)
; (VanillaINSERT (getpoint) "VLD_Tag" (getvar 'ctab))
(defun VanillaINSERT ( p nm spc / GetBlkAttDefProps atts r )
 ; '(87 114 105 116 116 101 110 32 66 121 32 71 114 114 114)
 (setq GetBlkAttDefProps
   (lambda ( bnm / e enx typ L )
     (and
       (setq e (tblobjname "BLOCK" bnm))
       (= 2 (logand 2 (cdr (assoc 70 (setq enx (entget e))))))
       (setq e (cdr (assoc -2 enx)))
       (while (and e (setq enx (entget e)) (/= "SEQEND" (setq typ (cdr (assoc 0 enx)))))
         (if (= "ATTDEF" typ) (setq L (cons (vl-remove-if-not (function (lambda (x) (member (car x) '(1 2 3 7 10 11 40)))) enx) L)))
         (setq e (entnext e))
       ); while
     ); and
     (reverse L)
   ); lambda
 ); setq GetBlkAttDefProps
 (cond
   ( (tblsearch "BLOCK" nm) (setq atts (GetBlkAttDefProps nm))
     (if
       (setq r
         (mapcar 'entmake
           (append
             (list
               (append
                 '((0 . "INSERT")(100 . "AcDbEntity")(67 . 0)) (list (cons 410 spc)) (list (cons 8 (getvar 'clayer))) '((100 . "AcDbBlockReference"))
                 (list (cons 66 (if atts 1 0)) (cons 2 nm) (cons 10 p))
                 '((41 . 1.)(42 . 1.)(43 . 1.)(50 . 0.0)(70 . 0)(71 . 0)(44 . 0.0)(45 . 0.0)(210 0.0 0.0 1.0))
               ); append
             ); list
             (if atts
               (mapcar
                 (function
                   (lambda (x / pt10 pt11 )
                     (setq pt10 (mapcar '+ p (cdr (assoc 10 x))))
                     (setq pt11 (mapcar '+ p (cdr (assoc 11 x))))
                     (append
                       '((0 . "ATTRIB")(100 . "AcDbEntity")(67 . 0))
                       '((8 . "0"))
                       '((100 . "AcDbText"))
                       (list (cons 10 pt10))
                       (list (assoc 40 x))
                       (list (assoc 1 x))
                       '((50 . 0.0)(41 . 1.0)(51 . 0.0))
                       (list (cons 7 (cond ((cdr (assoc 7 x))) ("Standard"))))
                       '((71 . 0)(72 . 1))
                       (list (cons 11 pt11))
                       '((210 0.0 0.0 1.0)(100 . "AcDbAttribute")(280 . 0)) (list (assoc 2 x)) '((70 . 0)(73 . 0)(74 . 2)(280 . 1))
                     ); append
                   ); lambda (x)
                 ); function
                 atts
               ); mapcar
             ); if atts
             (list (append '((0 . "SEQEND")(100 . "AcDbEntity")(67 . 0)) (list (cons 410 spc)) '((8 . "0")) ))
           ); append
         ); mapcar
       ); setq r
       ( (lambda ( c / ) (setvar 'cmdecho 0) (if acet-attsync (acet-attsync nm) (vl-cmdf "_.ATTSYNC" "_N" nm)) (setvar 'cmdecho c)) (getvar 'cmdecho) )
     ); if
     r
   ); (tblsearch "BLOCK" nm)
 ); cond
); defun VanillaINSERT
No worries, I was just testing the VanillaINSERT function - so heres one more condensed and reliable:
(defun C:test ( / SS spc f L i o1 tmpL o2 blks )
 (and '(87 114 105 116 116 101 110 32 66 121 32 71 114 114 114)
   (setq SS (ssget "_:L" '((0 . "INSERT"))))
   (setq spc (vla-get-Block (vla-get-ActiveLayout (vla-get-ActiveDocument (vlax-get-acad-object)))))
   (setq f (lambda (prp s d) (setq prp (vl-prin1-to-string prp)) ((eval (read (strcat "vla-put-" prp))) d ((eval (read (strcat "vla-get-" prp))) s))))
   (setq L '(HasAttributes IsDynamicBlock Layer InsertionPoint EffectiveName XScaleFactor YScaleFactor ZScaleFactor Rotation))
       (and
         (setq o1 (vlax-ename->vla-object (ssname SS (setq i (1- i)))))
         (setq tmpL (mapcar (function (lambda (x) (vlax-get o1 x))) L))
         (setq o2 (apply 'vlax-invoke (cons spc (cons 'InsertBlock (cdddr tmpL)))))
           (vlax-put o2 'Layer (caddr tmpL))
           (and (= -1 (car tmpL)) (setq blks (cons (nth 4 tmpL) blks))
             (foreach x (apply 'mapcar (cons 'list (mapcar (function (lambda (x) (vlax-invoke x 'GetAttributes))) (list o1 o2))))
               (apply 'f (cons 'TextString x))
           ); and
           (and (= -1 (cadr tmpL))
             (foreach x (apply 'mapcar (cons 'list (mapcar (function (lambda (x) (vlax-invoke x 'GetDynamicBlockProperties))) (list o1 o2))))
               (vl-catch-all-apply 'f (cons 'Value x))
           ); and
           (vla-Delete o1)
         ); progn
       ); and
     ); repeat
     (and blks
         (lambda ( / used )
           (setvar 'cmdecho 0)
           (foreach x blks
             (cond
               ( (member x used) )
               ( (setq used (cons x used)) (command "_.ATTSYNC" "_N" x) )
             ); cond
           ); foreach
           (setvar 'cmdecho 1)
         ); lambda
     ); and blks
   ); progn
 ); and
); defun C:test
@ Grrr:
To make the code truly reliable you would have to consider more properties: color, linetype, normal...
Why do you call the ATTSYNC command?
@ Grrr:
I agree, maybe an easy solution for that would be to make use of atoms-family to extract the required properties :
(setq prps
 (apply 'append
   (mapcar
     (function
       (lambda (x / prp)
         (if
           (and
             (wcmatch x "VLA-PUT-*")
             (vlax-property-available-p o (setq prp (substr x 9)))
           (list prp)
     (atoms-family 1)
Hm looks like its redundant, I was misleaded from my manual tests (rotating attributed block on 45 degrees and applying different x/y/z scales),
and forgot in the end that I was creating new references instead of manipulating the actual... :ouch:
Just a small hint:
when changing both the insertion point and the normal property of an object, pay attention to the order of those actions. It is not irrelevant.
Lee,
I was recenlty experimenting with these matrices - for blocks that are not scaled uniformly vla-transformby will error out:
Select block to synchronise attributes:
Error: Automation Error. Cannot scale nonuniformly;
Overall nice code!
Just a small hint:
Thanks Roy, however I still have less knowledge about:
wcs/ocs graphical objects, the trans function, the normal property, transformation matrices.
But I'm storing such hints for the future.
Sorry for the offtopic but:
Could you guys link me to a some startup information about how to understand these matrices,
so I'd knew how the object will be modified by the provided matrix?
(vla-transformby o (vlax-tmatrix mat))
Say theres this example:
; Rotates 90 degrees clockwise around '(0. 0. 0.) pt
'((0 1 0 0)
 (-1 0 0 0)
 (0 0 1 0)
 (0 0 0 1)
Is 0.0.0 pt always used as base? How to translate it so it uses a specified point instead of '(0. 0. 0.) ?
How do you change the angle there, like say: 45 degrees or 180
In the end you have to MxM to combine the result, I guess?
This is noted in Reply#5 of the linked thread - nonlinear transformations matrices cannot be used to transform objects in AutoCAD.
Ah I see now,
I just thought that you'd error-trap it or apply a /= check on the x/y/z block scales.
