Results 1 to 4 of 4
    Junior Member
    AutoCAD 2017
    Oct 2017
    19
    Question Writing text on a dimension arrow
    In the atachment below, a section of a circle can be seen which I previously drew plus a dimension line with text on it that I wrote.
    I can't recall how I managed to do this. Note that there's an arrow head at one end only.
    When I click dimension to repeat this, I'm just getting a length measurement.
    Could anyone remind me how to go about this?
    Thank you.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,851
    Given that the text begins with "R5" you probably used Dimension > Radius then opted to avail yourself of the Text option.
    You may also want to enable dimension text to be aligned with the dimension line (see Text tab).
    Junior Member
    AutoCAD 2017
    Oct 2017
    19
    Thanks.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,760
    if you have to go back and add text to an existing dimension, double click the dim text to open the dim text editor, arrow key the cursor to the right of the R5, and type in anything you want, click the open screen somewhere to exit the dim text editor.
    You will also find a Text Override line on your properties pallet, where you can enter more text, either instead of or in addition to the existing text. To do what your picture shows type <> my text here . the <> tells AutoCad NOT to overwrite the existing dim text. You can also type my text here <>. The <> tells AutoCad where to place the existing dimension text in relation to what you are adding in the override.
    If you obliterate the existing dimension text by accidentally overtyping it, you can get it back. Using either the first example of double clicking the dim text itself, or using the properties pallet, simply go back in the same way, select/highlight the current contents, and backspace until the text field is empty, then click some where else. The original dim text, R5, will re-appear back where it belongs.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  1. Writing Multiple lines of text to a text file
    By broncos15 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jul 2016, 12:14 am
  2. Cannot seem to get any arrow or dimension readings?
    By D1-Xen in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 16th Mar 2013, 03:18 pm
  3. Dimension arrow scales...
    By lamensterms in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Oct 2012, 02:13 am
  4. Replies: 16
    Last Post: 26th Dec 2010, 11:08 pm
  5. Dimension Arrow Heads as Blocks??
    By matt41129 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 29th Feb 2008, 04:53 pm
