Results 1 to 3 of 3
    Junior Member
    AutoCAD 2018
    Jul 2016
    UK, North Wales
    23
    Smile Mulytext selection
    Hi There,
    i have several text and few polylines in a drawing. I need to select all texts which is interact with or on the polyline.
    Unfortunately all those texts are created in same layer and same colour.
    Can any one help me please.
    Biji Samuel
    Junior Member
    AutoCAD 2018
    Jul 2016
    UK, North Wales
    23
    heloooooo
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,179
    It's not clear to me what the problem is. Do you want to select all text objects that intersect with a given polyline and ignore the rest? And there's nothing otherwise to distinguish any text object from any other text object?
    If you are lucky and the polyline is somewhat straight, you might be able to use a Fence to select them.
    If it's possible, you may have better luck putting the relevant text objects on their own layer. That's one of the reasons we have layers.
    Other than that, I don't know of any way (outside of LISP) to do exactly what you want.
    breaking AutoCAD on a regular basis since 1991
  1. Break Down Selection Set into smaller selection sets
    By broncos15 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Apr 2017, 03:33 am
  2. Create secondary Selection Sets from first Selection Set...
    By lamensterms in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Aug 2012, 10:39 am
  3. Trim selection & Object selection problem
    By Kurt Crim in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Aug 2011, 12:19 pm
  4. Replies: 1
    Last Post: 18th Nov 2010, 01:56 pm
  5. delay in selection of objects/selection windows
    By RedRobMol in forum AutoCAD Drawing Management & Output
    Last Post: 31st May 2005, 01:34 pm
