Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Forum Newbie
    Multi-disciplinary
    Civil 3D 2017
    Jan 2018
    6
    Default Edit to existing LISP routine
    Hi all,
    Really need a hand here.
    I have slightly edited the program from Lee Mac "areas2field" and added the line
    (setq format "%lu2%pr2%ps[, ha]%ct8[0.0001]") ;; Field Formatting
    This allows me to select a boundary and return the reading as an area in hectares, example output is "12.35 ha"
    I would like to modify output to also convert to acres
    for it to read like this "5.00 ac / 12.35 ha"
    Appreciated your help in advance.
    Forum Newbie
    Multi-disciplinary
    Civil 3D 2017
    Jan 2018
    6
    BTW, I attempted something like this (setq format "%lu2%pr2%ps[, ac]%ct8[0.0002471044] / %lu2%pr2%ps[, ha]%ct8[0.0001]") ;; Field Formatting
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,599
    Are you using Version 1.3 of the program from here?
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Forum Newbie
    Multi-disciplinary
    Civil 3D 2017
    Jan 2018
    6
    Quote Originally Posted by Lee Mac View Post
    Hi Lee, yes that's correct.
  5. #5
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,599
    Your code snippet made me think otherwise, as the current code does not have a 'format' variable.
    Nevertheless, as a quick fix, make the following changes:
    Change Line 31 from:
    Code:
        (setq fmt "%lu6%qf1") ;; Field Formatting
    to:
    Code:
        (setq fm1 "%lu6%qf1" ;; Field Formatting
              fm2 "%lu6%qf1"
    Change Lines 60-66 (inclusive) from:
    Code:
                    (setq str
                        (strcat
                            "%<\\AcObjProp Object(%<\\_ObjId "
                            (LM:ObjectID (vlax-ename->vla-object (ssname sel 0)))
                            ">%).Area \\f \"" fmt "\">%"
    to:
    Code:
                    (setq str
                        (strcat
                            ">%).Area \\f \"" fm1 "\">%"
                            ">%).Area \\f \"" fm2 "\">%"
    Change Lines 78-84 (inclusive) from:
    Code:
                        (setq str
                            (strcat
                                "%<\\AcExpr "
                                (apply 'strcat (reverse (cdr (reverse lst))))
                                " \\f \"" fmt "\">%"
    to:
    Code:
                        (setq str
                            (strcat
                                "%<\\AcExpr "
                                " \\f \"" fm1 "\">%"
                                "%<\\AcExpr "
                                " \\f \"" fm2 "\">%"
    And populate the variables fm1 and fm2 with the formatting for the fields on each side of the forward slash.
  6. #6
    Forum Newbie
    Multi-disciplinary
    Civil 3D 2017
    Jan 2018
    6
    Hi Lee,
    Thanks very much for that. I have made those adjustments however it's not working for me.
    I am not getting an error on load, it seems to work but is not output any text at all. It will realise I have selected an object then ask me where to place it, but shows up blank.
    I have uploaded a copy here, https://pastebin.com/fVv7phXS
    Could you please spot what I have done wrong?
    Appreciate your help!
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,599
    I think you misunderstood my instruction: "And populate the variables fm1 and fm2 with the formatting for the fields on each side of the forward slash."
    You should only change the values of fm1 & fm2, not substitute values where I have used these variables.
    i.e. When I instructed: "And populate the variables fm1 and fm2 with the formatting for the fields on each side of the forward slash.", I meant that you should set this part:
    Code:
              fm2 "%lu6%qf1"
    to your formatting of choice, e.g.:
    Code:
        (setq fm1 "%lu2%pr2%ps[, ac]%ct8[0.0002471044]" ;; Field Formatting
              fm2 "%lu2%pr2%ps[, ha]%ct8[0.0001]"
    Sorry, I thought this was clear.
  8. #8
    Forum Newbie
    Multi-disciplinary
    Civil 3D 2017
    Jan 2018
    6
    Surprise surprise I knew I would much it up.
    But it's very clear, changed it and works perfectly!
    Thank you so much.
  9. #9
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,599
    Excellent - you're welcome.
  10. #10
    Forum Newbie
    Multi-disciplinary
    Civil 3D 2017
    Jan 2018
    6
    Sorry one last question how can output this text as Arial Narrow with text height 2.5?
    Can it be done?
  1. Lisp routine to measure line and add length to existing text
    By emwhite in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Nov 2016, 11:31 am
  2. Need help on an existing offset lisp routine
    By vernonlee in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Feb 2015, 01:31 am
  3. Help with existing LISP routine
    By KHoughton in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Feb 2013, 11:02 pm
  4. Text edit lisp routine
    By jondoeiowa in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Aug 2011, 08:23 am
  5. dim text edit lisp routine??
    By BLOACH85 in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th May 2009, 09:11 pm
