Results 1 to 6 of 6
    Junior Member
    AutoCAD 2014
    Apr 2014
    18
    Default Batch Plotting on AutoCAD 2018 MAC Problem
    Ok so this is interesting and i can't figure it out. I've done multiple batch plots of a project with no issues. Then, I do my last plot today and its missing parts of the drawings. I have uploaded a portion of the title block showing the issue.
    But its not just in the title block. its in the drawings too. Lines of a table missing, text in the architectural Xref room callouts, text from the legend, etc.
    Anyone have a simple answer to this? I've tried multiple times to plot again with batch and its not fixing. But if i plot single pages its fine. Seems to only be in batch publish. Also, its not on every project. This is now the 2nd time in hundreds of projects i've had this happen.
    I've also went over to AutoCAD 2017 for windows and it does the same thing. Im racking my brain trying to figure this out.
    Any ideas to fix would be greatly appreciated.
    Senior Member
    iconeo's Computer Details
    Windows
    Multi-disciplinary
    iconeo's Discipline Details
    CAD Manager/Draftsman
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    290
    I see that your client is KP. Since they are 'evil' maybe your computer has a demon that it can't shake.
    My best guess would be a font embed problem with publish. Double check these settings and see what turns up.
    Junior Member
    AutoCAD 2014
    Apr 2014
    18
    of course they are evil, but they also pay on time and give us tons of business. So I can't complain
    So i was able to uncheck 'Keep TrueType Fonts' and it published fine. Why would this now be a problem when before it wasn't? We didn't change fonts or anything. Literally just did some minor revisions to the drawing set and replotted.
    Senior Member
    Windows
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    290
    No real idea. I just blame it on bad programming.
  5. #5
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    Not a Flaming, simply trying to keep you employed.
    So you've published your company name, and your clients name on a public forum and described the client as evil.
    I suggest finding the delete option on the EDIT POST dialog ASAP.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  6. #6
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,947
    Did you upgrade your computer when you upgraded the software? What Fonts seem to be a problem?
    What OS and Computer Specifications (for both the MAC and the Windows you tried)?
    Haven't used 2018 for batch plotting much, I'll try to have a look here for that problem, when I get some time.
  1. AutoCAD 2018 with Fabrication MEP 2018 plot bug
    By Cerryl in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 28th Dec 2017, 07:53 pm
  2. Batch plotting PDF Autocad 2014! HELP!
    By tmelancon in forum AutoCAD Drawing Management & Output
    Last Post: 21st Apr 2014, 08:20 am
  3. Sheet Set- Batch Plotting problem
    By TXGABE in forum AutoCAD Drawing Management & Output
    Last Post: 4th Nov 2011, 02:44 pm
  4. Problem with batch plotting
    By CADuser20 in forum AutoCAD General
    Last Post: 30th Jul 2009, 10:26 pm
  5. Batch Plotting in AutoCad 2007
    By PC Digital in forum AutoCAD Beginners' Area
    Last Post: 20th Jul 2009, 12:49 pm
