Creating dwg files (dwg. format) using Excel sheet.
Guptil
I have a Excel sheet showing around 500 drawings numbers and i would like to create just dwg files with the same drawings numbers as shown in excel. any help in this regards will be highly appropriated.
Like maratovich lots of missing answers here.
Do you just want to create blank dwgs with a new name ?
Do they need to have something drawn inside each one ?
Do they ned a title block created with dwg name ?
500 blank dwgs can be done outside autocad by copying a predefined dwg using a batch file. Take advantage of excel to create.
I would use a batch file like the one below
setLocal EnableDelayedExpansion
SET count=
for /f "tokens=* delims= " %%x in (c:\Temp\filelist.csv) do (
REM ["-----template file to be copyed-----"]["-----location of new files-----\%%x"]
cOPY "[color="red"]Template File[/color]"  "[color="red"]New file location[/color]\%%x" /y
endlocal
The filelist.csv would have to be in the following format.
drawing 1.dwg
drawing 2.dwg
drawing 3.dwg
drawing 4.dwg
drawing 5.dwg
Edited by SunnyTurtle
  • Thanks 1
Just Empty drawings with a name as shown in excel sheet.
SET count=
endlocal
drawing 1.dwg
drawing 2.dwg
drawing 3.dwg
drawing 4.dwg
drawing 5.dwg
Where is thumbs up button..:D:thumbsup: :thumbsup:
Thanks allot. It works like a champ.
  • 6 months later...
Hi All,
Hope I am not too late here.
I am at rookie level at VBA in excel and totally new to VBA in CAD.
I am also have the same requirement as that of Mr. Guptil.
Till yesterday I was looking for a VBA code in excel.
Can anyone guide me through this.
Thanks in advance.
@ maratovich... thanks for the response and attachment.
@Bigal: thanks for the "batch" file process explanation.
Both options are helpful to an extent.
Anyways, i will keep on exploring other options and post here when find any suitable.
Cheers !!!!
Dear Bigal,
Thanks for the explanation of batch process. Though renaming isn't accepting "spaces", it is also helpful to some extent.
Thanks again.
  • 3 weeks later...
Here's another method creating multiple new drawing by LISP
(defun c:newdwg (/ dwg dwgname str l i ls ok fold fn)
  ;hanhphuc
  (if (not *start-End*)
    (setq *start-End* "1-10")
  (if (and (setq dwgname "Drawing " ; <-- default output prefix
		 dwg (getenv "lasttemplate"))
	   (setq str (getstring (strcat "\nEnter start-end number [" *start-End* "] : ")))
	   (setq *start-End*
		  (cond	((and (/= *start-End* "") (= str "")) *start-End*)
			((wcmatch str "#*-*#") str)
			(t "1-10")
	   (setq l (read (strcat "(" (vl-string-translate "-" " " (read *start-End*)) ")")))
	   (setq i    (1- (car (vl-sort l '<)))
		 fold (acet-ui-pickdir)
      (repeat (1+ (abs (apply '- l)))
      (setq ok (vl-file-copy dwg (setq fn (strcat fold "\\" dwgname (itoa (setq i (1+ i))) ".dwg"))))
      (if (not ok)
	(setq ls (cons fn ls))
      (princ (strcat "\nTotal "(itoa (- (apply 'max l)(length ls))) " new drawings created."))
    (princ "\nInvalid file name or folder")
  (if ls
    (progn (princ (strcat "\n" (itoa (length ls)) " duplicate files : "))
	   (foreach x (reverse ls) (terpri) (princ x))
In order to minimize user input,  get rid of 'getstring' for output drawing prefix
also use minus sign '-'  as delimiter upon prompt for input.
Command: NEWDWG
Enter start-end number [1-10] : 1-10
Total 7 new drawings created.
3 duplicate files :
C:\Users\hp\Desktop\CAD\Drawing 1.dwg
C:\Users\hp\Desktop\CAD\Drawing 2.dwg
C:\Users\hp\Desktop\CAD\Drawing 3.dwg
Edited by hanhphuc
