Results 1 to 2 of 2
    Forum Newbie
    Education
    AutoCAD 2018
    Jan 2018
    1
    Default Changing the chord of a propeller while keeping the diameter and pitch constant
    Hi everyone!
    I've an apc 8x3.8 propeller CAD file and I've to modify the chord length while maintaining the pitch and diameter but I'm not sure how to go about doing it. The airfoil used is the NACA 4412. Any ideas?
    Melissa
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    This technique only applies to a 2D section of one of your propeller blades. Maybe it will give you a starting point.
    Since the chord length is the straight line width of the propeller blade in a given spot, (see attached image) changing the chord length will not affect the rotating diameter of the propeller, nor the pitch (angle of the blade in relation to the propeller shaft).
    However, just changing the chord length, and nothing else, will make the cross section of the blade either flatter or more curved, since the cross section will be either wider or more narrow respectively. This will destroy your (I assume) objective of retaining the original airfoil shape. However, there is an easy way to change the chord length in cross section view only without losing the correct airfoil shape.
    To do the above, you can simply use the Scale command, with the Reference sub-command. This will proportionally change the size of the airfoil overall, retaining the profile shape.
    First, draw a new line (different color) at the desired length directly over your original chord length line starting at one exact end of the original line.
    Now execute SCALE.
    Click the common end of your two chord length lines as your Base Point.
    Type R(for reference).
    Click the Base Point again. Then, click the other end of your original chord length line.
    Now click the other end of your new chord length line and exit (esc) the Scale command.
    erase the new line you drew for the reference.
    You now have a new chord length, and the original airfoil profile has been retained.
    Now, changing the overall chord length in 3D is out of my league.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  1. Changing Dynamic block name, AND keeping attributes
    By JeremyA1976 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Feb 2014, 08:16 am
  2. Roof pitch
    By almondjoy in forum AutoCAD Beginners' Area
    Last Post: 17th Sep 2012, 04:52 am
  3. 8/12 roof pitch?
    By kristinabrooke in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Jun 2012, 04:11 pm
  4. changing diameter to nearest value
    By razaim in forum AutoCAD Beginners' Area
    Last Post: 3rd Sep 2009, 05:30 am
  5. changing default constant width
    By Totes100 in forum AutoCAD General
    Last Post: 3rd Apr 2004, 12:24 am
Tags for this Thread
