Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 34
    Senior Member
    AutoCAD 2014
    May 2014
    158
    Default How to Draw This?
    Can someone please tell me how to draw a continuous curve like below pic (the blue curve) start from point A through point B and end at point C.
    The one I had drawn on above pic is not continuous at point B. It's like a two different curves, the A-B curve and B-C curve, joined together at point B.
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,174
    There are a few ways to get that done, but the important point is if you want it to be continuous the two arc centres should be on a straight line that passes through the tangent point. I placed the yellow dashed circles first to find the lower arc's center point, that gives you 2 points for drawing the straight green line, then you just have to find the point on that green line for the upper arc.
    And this way starting from the top arc
    The dwg is for the first method, I'll let you figure out the points for the second
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
    Senior Member
    AutoCAD 2014
    May 2014
    158
    Quote Originally Posted by steven-g View Post
    The shape of B-C arc is not what I want.
    The shape is too concave.
    As you can see, the B-C arc intersect C-E hidden line at D and C-D arc is exceed the C-E hidden line.
    This is not what I expected.
    The one I expect is that the B-C arc does not exceed the C-E hidden line.
    From what I see is, you draw the A-B arc first than next you draw the B-C arc.
    What about if I draw the B-C arc first then next the A-B arc?
    Can you show me this method by an image like above?
    This is the dwg file for you.
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,174
    Use the same method as the first option if you use the ray command pick the start point as the center of your arc and the second point is B, then the center of your arc AB is somewhere on that line.
  5. #5
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,154
    It is easy enough to draw continuous arcs, but there are many solutions to the measurements shown in your diagram.
    You need to give more information or another dimension to get it how you want it to look.
  6. #6
    Senior Member
    AutoCAD 2014
    May 2014
    158
    Quote Originally Posted by eldon View Post
    The blue arcs is the same as steven-g made, no.
    The shape of magenta arcs is weird.
    The green arcs is my best choice.
    Can you show me how to make the green arcs continuously?
  7. #7
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,853
    Quote Originally Posted by basty View Post
    Can you show me how to draw the green arc?
    How about you follow the advice that was given first? "You need to give more information or another dimension to get it how you want it to look."
    I'm retired now.....not dead. I have a few working brain cells left.
  8. #8
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,154
    I offset the top line upwards by 1 (the actual offset distance is not important) so that point A is vertically above point B. This ensures that the tangent at B is vertical.
    Now draw a line from A to B. End the line command and start the arc command. When the start point is needed (look at the command line), just press Enter. The arc will now start drawing from B with the tangent vertical. The endpoint of the arc is point C. Start the arc command again, and again when it says "Specify start point of the arc", merely press enter. A new arc will start, tangential to the previous arc. The end point is D.
    Erase the temporary line AB.
  9. #9
    Senior Member
    AutoCAD 2014
    May 2014
    158
    All dimensions were already provided in post #1.
  10. #10
    Senior Member
    AutoCAD 2014
    May 2014
    158
    Can you show me how to draw these green arcs by graphical method like steven-g did in post #2?
  1. My First Draw
    By egytopp in forum AutoCAD Beginners' Area
    Last Post: 12th Jun 2014, 06:53 pm
  2. How would YOU draw this? Can it be done?
    By bbankston in forum AutoCAD Beginners' Area
    Last Post: 22nd Oct 2010, 04:13 pm
  3. How can I draw this ? Help
    By Run 4 Your Life in forum AutoCAD 3D Modelling & Rendering
    Last Post: 7th Dec 2009, 08:07 pm
