Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 34
  1. #21
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,852
    Radii is the plural of radius. Since you have two arcs the term "radii" would apply. Again, you should know this from school.
  2. #22
    Senior Member
    AutoCAD 2014
    May 2014
    156
    So, how do I draw the green arcs shown in post #5?
  3. #23
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,852
    Do you want an ogee curve? Look it up.
    We will need some curve data.
  4. #24
    Senior Member
    AutoCAD 2014
    May 2014
    156
    What's a "ogee curve"?
  5. #25
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,149
    Following through on Eldons post #8 using that technique but replace point A with any point you want in the entire modelspace and you can draw curves through point BCD that are continuous.
    But this thread is very much a case of "you can lead a horse to water but you can't make him drink"
    Basty if you cannot see that drawing a line in your dwg from #3 between A an B and finding where a line drawn perpendicular from the center of that line crosses a ray drawn between the center of your arc and point B then it is time that you seriously start looking for another profession. I'm not being abusive here or cruel or picking on you, this is just the cold hard truth, some people just are not suited to certain jobs. And that is the end of my input on this thread.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  6. #26
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,131
    Quote Originally Posted by basty View Post
    I know that you have posted this in the Beginners section, but I hope that you have discovered all the Drafting Settings that make life easy.
    For example drawing the perpendicular bisector of a line. The old fashioned way is to strike an arc from each end of a line, and then draw a line between the intersecting arcs. But using AutoCAD's drafting Settings with Polar Tracking on, one merely draws from the mid point of the line.
    Another example is when you want two lines to extend to meet at a point, use the Fillet command with the radius set to 0.
    So back to the matter in hand which is to draw the green arcs. This is a special case where the uppermost point of the arc is tangentially vertical.
    Draw the chord B-C. Draw the perpendicular bisector to meet the line B extended at E.
    Draw the chord C-D. Draw the perpendicular bisector to meet the line E-C extended at F.
    E and F are the centres of the circles, which now you can draw. Trim the circles, tidy up all temporary construction lines and there you have it.
  7. #27
    Senior Member welldriller's Avatar
    welldriller's Computer Details
    Windows 10 Home
    Dell inspiration 3650
    x64 processor
    8 GB
    Dell P190SB#4
    Solidworks 2017
    Jan 2013
    Federalsburg, Maryland
    308
    ReMark gave you the answer in post #13. POLYLINE
  8. #28
    Senior Member
    AutoCAD 2014
    May 2014
    156
    @ReMark
    How do I draw an ogee curve and reverse curve?
    Can someone please teach me that?
    If anyone can, please move this thread to the drafting section.
  9. #29
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,511
    nail down jello
    Hi Remark was watching a show on Foxtel and some smart people added a chemical to water, it still acts like water but provide a violent reaction and it turns solid, they did stuff like run across it no problems, walk slowly and just sank, rode a bicycle across it !. So maybe hammer a nail into jello.
    Basty you need to do some homework on curve interaction, google land surveyors formula for curves.
  10. #30
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,511
    This is a pline using a repeating arc function within the pline command.
  1. My First Draw
    By egytopp in forum AutoCAD Beginners' Area
    Last Post: 12th Jun 2014, 06:53 pm
  2. How would YOU draw this? Can it be done?
    By bbankston in forum AutoCAD Beginners' Area
    Last Post: 22nd Oct 2010, 04:13 pm
  3. How can I draw this ? Help
    By Run 4 Your Life in forum AutoCAD 3D Modelling & Rendering
    Last Post: 7th Dec 2009, 08:07 pm
  4. How do I draw this?
    By Daniz in forum AutoCAD Beginners' Area
    Last Post: 14th May 2008, 03:05 pm
  5. how do you draw..
    By James281 in forum AutoCAD General
    Last Post: 16th Nov 2005, 12:09 am
