Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 34 of 34
  1. #31
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,845
    Quote Originally Posted by basty View Post
    @ReMark
    How do I draw an ogee curve and reverse curve?
    Can someone please teach me that?
    If anyone can, please move this thread to the drafting section.
    Have you looked at post #26 by eldon?
  2. #32
    Senior Member
    AutoCAD 2014
    May 2014
    156
    What about if I draw the B-C arc first like post #19?
    How do I draw the A-B arc?
    [IMG][/IMG]
  3. #33
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,131
    ......How do I draw the A-B arc?
    Draw the perpendicular bisector between A and B. Draw the line D to B and extend it to the perpendicular bisector at F. F is the centre of the circle.
    Last edited by eldon; 23rd Jan 2018 at 09:29 am. Reason: point nomenclature correction
  4. #34
    Senior Member lrm's Avatar
    lrm's Computer Details
    Windows 7 64-bit
    16 GB
    Education
    lrm's Discipline Details
    Teacher, AEC and mechanical
    Education
    Civil and Mechanical
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    371
    As noted, there are an infinite number of solutions to this problem but they all as Steven-g noted must have " two arc centres should be on a straight line that passes through the tangent point".
    I created a parametric model (see attached file) that lets you dynamically review the solutions. Just drag the free end of the yellow or magenta lines and the arc radii and location will adjust automatically. It should be noted that in order to determine and reference the intersection point of the yellow line and the blue line (the perpendicular bisector) I cheated a bit. There is a small circle (0.01 dia) that is tangent to the two lines. This circle is used as the reference point for the center of the arc. There is a collinear constraint between the yellow and magenta lines
    A Screencast of the movement is here: http://autode.sk/2DCVzXR
    HowToDrawThis-1.dwg
  1. My First Draw
    By egytopp in forum AutoCAD Beginners' Area
    Last Post: 12th Jun 2014, 06:53 pm
  2. How would YOU draw this? Can it be done?
    By bbankston in forum AutoCAD Beginners' Area
    Last Post: 22nd Oct 2010, 04:13 pm
  3. How can I draw this ? Help
    By Run 4 Your Life in forum AutoCAD 3D Modelling & Rendering
    Last Post: 7th Dec 2009, 08:07 pm
  4. How do I draw this?
    By Daniz in forum AutoCAD Beginners' Area
    Last Post: 14th May 2008, 03:05 pm
  5. how do you draw..
    By James281 in forum AutoCAD General
    Last Post: 16th Nov 2005, 12:09 am
