Results 1 to 8 of 8
    Senior Member
    Construction
    wimal's Discipline Details
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    443
    Default Correct font style not loading
    I have created a font style named MY Standard and load font Arial narrow.
    But some times when copy and paste the text that in the same drawing,the instead of Arial narrow it loading some other font type even Arial narrow fonts are available. How can I stop this error.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,736
    You copy/paste text in the same drawing or between two different drawings?
    You're telling us that there are two or more fonts named Arial Narrow and they look different from each other?
    Is "My Standard" a font style that is included as part of your template file?
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    760
    My guess is there already was a Text Style named MY Standard in the drawing associated with a different font.
    Best way to avoid this is to use descriptive Text style names like "Arial Narrow" instead of "MY Standard". Then there's never any question what font is assigned to your Text Styles.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
    Senior Member
    Construction
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    443
    Thanks for advice of both of you. When the next time it happened I will send a screen shot to ex-plane the problem.
    http://www.cadtutor.net/forum/showth...displays-wrong The same problem happening to me also.
  5. #5
    Super Moderator
    rkmcswain's Computer Details
    Windows 7 Pro x64
    HP ZBook 17
    i7-4810MQ @ 2.80 GHZ
    16GB
    Nvidia Quadro K4100M
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    rkmcswain's Discipline Details
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,487
    Quote Originally Posted by wimal View Post
    Note that TextStyles and Fonts are not the same thing.
    You can create a TextStyle named "MY Standard" and assign it the font "Arial Narrow"
    Then your co-worker can create a TextStyle named "MY Standard" and assign the font "Calibri" (or txt.shx, or romand.shx, etc)
    The name of the TextStyle "MY Standard" is only a name. The font assigned to that TextStyle determines how it will look, in a given drawing.
    R.K. McSwain
    CAD Panacea | twitter
  6. #6
    Senior Member
    Construction
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    443
    The font type Arial is available. But loading arialn.ttf this is the error.
  7. #7
    Super Member
    Windows 7 64-bit
    Dell
    Civil
    Design Analyst
    Civil
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    760
    The gold triangle means it cannot be found. If you change the Font to Arial, save and close then try to change it back it will not be listed. Check you Windows Fonts folder, it's not in there either.
    This drawing or the template it was created with had that added by someone who had access to ARIALN.TTF, but for now at least you don't.
    You really need to stick with matching Text Style names, bet I can guess what fonts ROMANS and Simplex have assigned to them. AutoCAD can be as easy as you let it be.
  8. #8
    Senior Member
    Construction
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    443
    Thanks TOMBU for your advice.
  1. Font correct in style, displays wrong
    By Tiger in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 8th May 2017, 10:07 pm
  2. I need a lisp to correct all damage text font in dwg file ??::
    By hosyn in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Nov 2014, 06:01 am
  3. Friday Teaser - Font style changing in text style
    By feargt in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Jul 2010, 09:39 am
  4. Font Style
    By rodbuilder in forum AutoCAD General
    Last Post: 19th Jan 2010, 11:29 pm
  5. Style vs Font
    By johnengineer in forum AutoCAD Beginners' Area
    Last Post: 9th Jul 2007, 05:20 pm
