Results 1 to 4 of 4
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    35
    Default Polar stretch help
    I have a dynamic block with many features and several visibility states. However, I am having one issue with Polar stretch.
    I have a vertical pline with a short horizontal pline perpendicular at the bottom. I have the polar parameter and polar stretch attached to the lines to rotate around the upper end point. I want the short perp. pline to stay horizontal to the polar stretch point, but am having difficulty figuring that out.
    I have tried a horiz. geometric constraint, but I need the line to stay a set length and it wants to shorten as I rotate it. I have tried a locked constraint, but I need the pline to scale when a lookup scale factor is selected and it won't scale.
    Any help on this would be appreciated.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,076
    Can you post the .dwg?
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    35
    Posting the block or a drawing is unnecessary.
    All it is, is a vertical line with a short line horizontal off the bottom end of the line (could be joined or individual lines). Think of a section cut tail.
    The pivot point should be the top end of the vertical line. The bottom end of the vertical line is the polar stretch point.
    I would like the horizontal line to pivot (staying horizontal) at the polar stretch point, while moving with the polar stretch point (staying "connected" at the ends of each line).
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    35
    I figured out my own dilemma. I needed to use the parameter set of 'Polar Stretch Pair' to keep the horizontal line horizontal while polar stretching the vertical line as it stretched in both x-y direction.
  1. How to chain a linear to a polar stretch?
    By marcus007 in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Oct 2016, 07:36 am
  2. Polar stretch
    By musicfix in forum AutoCAD Drawing Management & Output
    Last Post: 15th Feb 2015, 09:05 pm
  3. Polar Stretch and Linear Stretch don't work together?
    By Asterisk in forum AutoCAD Drawing Management & Output
    Last Post: 31st Jul 2011, 06:35 am
  4. Polar stretch
    By Shahin in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Jul 2010, 06:56 pm
  5. polar stretch arrays
    By crumpysmom in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 17th Apr 2008, 03:12 pm
