Results 1 to 3 of 3
    Junior Member
    AutoCAD 2009
    May 2015
    16
    Default copying XREF-layersettings between Xref's
    I have a drawing with currently 5 xrefs. These Xrefs are not from our company and don't come from autocad. They are a dwg export. Each xref has +-500 layers. I don't want to put them together because these xrefs are changing sometimes.
    For the first xref, I have applied some changes to the layers:
    - layers OFF
    - changed color of layers (mainly change colors to grey - colors 252 tot 254)
    - changed linetypes
    I would like to apply these changes to all my Xrefs. Currently 5 xref but more need the be added to the drawing.
    Can I copy my setting from xref1 tot the other xrefs?
    All xref have there own name but their layers are the same (some minor exeptions).
    Senior Member
    OMEGA-ThundeR's Computer Details
    Windows 10
    HP Z440
    Civil
    OMEGA-ThundeR's Discipline Details
    Civil Engineer (CAD Design)
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    320
    I would say, if the layers are the same, use one 1 of the xref files as a template (with all the layer settings), remove the content -> copy content from other xref files to the 'template' xref -> save that current xref with a other name -> repeat untill all xref's have been updated.
    For 5-10 files that shouldn't take more than a few minutes of work (depending on how much information is in them).
    But i think something like the 'layer states' would do the trick also : https://knowledge.autodesk.com/suppo...20068-htm.html
    I'm not sure if that does the trick though, i know for sure my first suggestion would work (unless these layer settings are done in the properties of the objects, and not in the layermanager!)
    Junior Member
    AutoCAD 2009
    May 2015
    16
    I still have to look at the use of "layer states" and see if it works.
    Some xrefs are updated on a regular basis. So it is important that I can simply adjust the xref link to the new file without applying all layer chages again.
  1. Copying all objects from Xref to Drawings
    By jasonyctam in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jan 2015, 09:29 pm
  2. Moving Drawing and/or xref to new locations while Xref keeps path
    By Efeezy in forum AutoCAD Beginners' Area
    Last Post: 28th Jun 2014, 01:26 am
  3. Copying Linework from Xref into base file - Unnecessary Rotation
    By edoll in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 1st Nov 2012, 05:59 pm
  4. Annotative text in XREF? Xref units mm, parent drawing m
    By spittle in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Aug 2009, 09:06 am
  5. copying an xref within same drawing
    By td88 in forum AutoCAD Beginners' Area
    Last Post: 7th Apr 2009, 01:53 pm
