Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    34
    Default Layer group help
    Is there a way to transfer layer groups from one drawing to another?
    Not layer states or layer filters. Layer GROUPS.
    Thanks
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    760
    They are actually a type of layer filter: http://blogs.autodesk.com/autocad/au...-tuesday-tips/
    You can use ExpFltr to export layer filters and ImpFltr to import them with LayerFilter.LSP: http://forums.augi.com/showthread.ph...l=1#post952247
    I have Buttons at the top of Layer Properties Manager Palette for doing saving and loading layer filters as well, the Save one is the standard Save button that looks like a 3½" diskette. The Load layer filter button is just to the left of it.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    34
    The first link shows how to create layer groups and nesting groups, etc. I already know how to create layer groups, I am wanting to transfer those layer groups to another dwg without having to actually re-create the different layer groups and migrate layers into them in a second dwg. or a third or fourth.
    Please don't confuse layer groups with layer filters. They are different. I know how to work with layer filters, but my question is about layer groups. I cannot download the LISP routine to test it from the other link because I am not a member on that page. It won't let me download without joining, so unless you can attach the LISP here, I am back in the same boat.
    There has to be a simple way to export/import layer groups.
    Super Member
    Windows 7 64-bit
    Dell
    Civil
    Design Analyst
    Civil
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    760
    The three types of Layer Filters are Properties, Standards, and Groups. There is no other type of Layer Group I know of. The Autodesk blog link above shows how to create Group Filter named [Group Filter1] under Filters. Sorry, the buttons I described before may only be in verticals like Civil 3D and Architectural.
    You can easily create one with a macro starting with
    Code:
    -LAyer _filter _New _Group
    Lots of lisp options as well if you're comfortable with that: http://www.cadtutor.net/forum/showth...r-group-filter
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,959
    What's the problem with signing up at AUGI to get the LISP?
    As tombu has told you, a Layer Group is a type of Layer Filter, the AutoCAD Verticals I believe can import/export filters (at least some of them, if not all), but programming is the only way to do it with the Vanilla AutoCAD.
  6. #6
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    34
    I must not be understanding something. I am using AutoCAD 2018.
    What I am trying to do is transfer layer groups from one dwg to another. I can transfer layers by copying and pasting objects on those layers. However, I can't transfer the groups they are in to the second dwg.
    Maybe type a little slower for me.
    I am attaching a snipit of my layer manager to show what I see. There is no way to save the groups.
  7. #7
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,959
    Plain AutoCAD cannot Export and Import Layer Filters, you will need to purchase a Vertical product, i.e. Civil3D or use a LISP or some other form of third party programming.
  8. #8
    Super Member
    Windows 7 64-bit
    Dell
    Civil
    Design Analyst
    Civil
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    760
    Using a macro to add a Layer Group Filter is easy enough. Here's one I use for layers added when running AutoTurn:
    Code:
    ^C^C(command "-LAYER" "filter" "New" "Group" "All" "ATDIMS,ATTEXT,ATVEHICLE,AutoTURN,TSCONFLICT,TSINVISION,TSOBSTACLE,Veh-P" "AutoTurn" "eXit" "")
    Just replace the layer names seperated by commas "ATDIMS through Veh-P" and replace "AutoTurn" with the group filter name you would like to use.
  9. #9
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    34
    This worked like a charm. However, a little tedious in getting the several buttons I needed to create each group layer to add to each dwg. Thanks.
    I never could figure out the EXPFLTR LISP as pointed out above. It kept giving me the "None property layer filter in this drawing" message as embedded in the code. Oh well, my macro buttons are working.
    Thanks again.
  10. #10
    Super Member
    Windows 7 64-bit
    Dell
    Civil
    Design Analyst
    Civil
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    760
    Quote Originally Posted by robwell View Post
    Thanks again.
    Sorry, I've been using Civil 3D for many years now and forget many of the commands and options for even simple stuff like working with layers is pretty limited in vanilla AutoCAD.
    Glad those macros worked out for you.
  1. new group layer filter
    By Rudbeckia in forum AutoCAD Drawing Management & Output
    Last Post: 21st Jul 2016, 05:35 pm
  2. Lsp to create groups by layer, with layer name as group name
    By Oni in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Nov 2015, 12:38 pm
  3. how to look at dxf group code of a layer
    By Jef! in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Dec 2013, 12:34 am
  4. layer group filter
    By pmxcad in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Aug 2011, 12:31 pm
  5. layer group and general layer question
    By jkristia in forum AutoCAD Beginners' Area
    Last Post: 29th Nov 2008, 12:56 pm
