Results 1 to 8 of 8
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    35
    Default Dynamic block issue
    I am having difficulty finding the solution to a problem with my dynamic block.
    I hope the image helps. I would like the pointer to double pivot, but the arrowhead to stay inline with the top line.
    I can do this if I don't rotate the direction first. If I rotate first, the the stretch dynamic does not stay in place with the pointer and it goes crazy in it's placement.
    Any help is appreciated. Thanks.
    Here is the file. pointer.dwg
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    35
    Anyone have any input on a fix for this?
    Senior Member
    iconeo's Computer Details
    Windows
    Multi-disciplinary
    iconeo's Discipline Details
    CAD Manager/Draftsman
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    292
    So you want the arrowhead to remain pointing in the same direction as the main callout arrow?
    Senior Member
    Windows
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    292
    Can you provide some examples of how you want it to look in different positions?
  5. #5
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    35
    Yes. Here is a snipit example of positions.
  6. #6
    Super Member
    Ski_Me's Computer Details
    DELL (why oh lord must I suffer)
    Electrical
    Ski_Me's Discipline Details
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    638
    You would have to constrain the arrow to the call out tag but I think the arrow would need a point to rotate around as well.
  7. #7
    Senior Member
    Windows
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    292
    Try this and let me know if it works.
  8. #8
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    35
    That works perfect iconeo. Thanks.
    However, I am so stupid. While looking at your block and trying to figure out how you did it, I realized (had a DUH ME moment) as to why my original block wasn't working properly. I had unintentionally included the stretch action in the scale and rotate actions and when I removed it from both, the block worked perfectly. See attached.
    So, in yours, while the perpendicular, parallel, equal, move and coincident restraints work together to achieve what I was looking for, a simple stretch on polar parameter does the same exact thing without the need for those other actions or restraints.
    Thank you tremendously for your help though.
  1. Dynamic Block - strech issue
    By Verbrugghe in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 17th Feb 2015, 12:58 pm
  2. Dynamic Block - rotating reference issue
    By jalbes in forum AutoCAD Drawing Management & Output
    Last Post: 6th Apr 2013, 03:10 pm
  3. Dynamic Block Issue
    By woodman78 in forum AutoCAD Drawing Management & Output
    Last Post: 9th Oct 2012, 04:42 pm
  4. Dynamic Block Scaling issue...
    By erratic in forum AutoCAD General
    Last Post: 10th Feb 2010, 06:40 pm
  5. Dynamic block array issue
    By Seann in forum AutoCAD General
    Last Post: 5th Jun 2007, 05:36 pm
