Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2010
    Mar 2016
    3
    Default Please help an old 2D guy with a Loft
    Hello Everyone,
    Goal - Getting help with creating accurate Sectional Views from a Loft.
    I apologize in advance for the large picture size.
    I am hoping an old AutoCAD "2D" guy can get some help/assistance from the experts here that know what they're doing. I'm the first to admit, that in the world of 3D...I am clueless. Hunting and pecking just does not replace accurate knowledge.
    Thank You Guys for all your help in advance!
    Here is my issue(s). I am working on creating an aircraft fuselage section that is 60 inches long. The fuselage is wider and taller at the back as the "outer face" slims down as it moves forward. The inside face remains constant over the 60 inches. I need help with creating accurate sectional views at specific points along the loft.
    Rather than try to describe each issue, I have posted screenshots below to help you understand how little 3D knowledge I really have and what I'm trying to do.
    The first picture is the Backface on the left and Front face on the right. The Pink lines represent the 1st Rib on the left, (Backface) and the Last Rib on the right, (Front face). The Yellow beveled box atop each Rib is a beveled 2 x 4 that will run from the Top of the Back Face to the Top of the Front Face.
    The next picture shows what I mean by saying the "inside face edges" remain constant across the loft. This is just stacking the two Ribs on top of each other with the left lower corner points aligned. The inside should not change, the outside should.
    This is the process I went through (which I'm sure is wrong) to get the Loft created from Back to Front.
    Created the 2D polyline segments.
    Placed them 60 inches apart on the same plane.
    Created the Loft by selecting the Backface first, then the Front Face next.
    NOTE - I removed Yellow 2x4 Line Segment as it caused even more erroneous behavior for the loft than without it. I ultimately would like to have it included in the Sectional Views.
    Now "assuming" what I have so far is accurate, (I use that term lightly as I know I've screwed something up). The loft "appears" to have been created correctly. It shows the back to front sliming as I wanted and the inside edges "appear" to remain constant.
    Next, I need to create "Accurate" 2D Sectional drawings from the intervals listed below, to create the individual Rib Stations.
    No matter what I try, the sectional views come out as shown below. Any and all help is greatly appreciated. Thank you guys in advance for all your help.
    Forum Newbie
    AutoCAD 2010
    Mar 2016
    3
    For some Reason, I can not edit my post ???
    I attached a simple 2D drawing of the 2 ribs and the beveled 2x4 from the post above.
    Thanks for the help.!
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,599
    change first so you have a top view of the objects, then initiate the section command. You can use the BaseView commands and then make sections from that view as well.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Forum Newbie
    AutoCAD 2010
    Mar 2016
    3
    Thank You RKent,
    I have no clue why it worked so well with your instructions but it did, and it worked perfectly.
    I am very thankful for your knowledge and willingness to share it with me.
    Have a great weekend!
    TB
  5. #5
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2017
    Nov 2007
    4,599
    Glad to hear it worked for you. Always glad to help.
  1. LOFT help!!!
    By JPlanera in forum Autodesk Inventor
    Last Post: 21st Apr 2014, 03:32 pm
  2. Looking for help with Loft cut
    By BikeGuy in forum SolidWorks
    Last Post: 3rd Sep 2013, 04:45 pm
  3. How to Loft This?
    By spinecad in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Mar 2013, 02:54 pm
  4. How can I fix this loft?
    By krautfed in forum Autodesk Inventor
    Last Post: 24th Feb 2009, 11:00 pm
