Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Junior Member
    AutoCAD 2014
    Apr 2015
    20
    Default Multiple lines with user input..
    Hi Guys... can some one help me to develop a lisp...
    I need to draw multiple lines with user input
    Ex. Length, Number of lines, offset size
    also need draw vertical lines both ends 1/16" inside...
    I have attached Image as an example
    Thanks in advance....
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,076
    I have moved your thread to the AutoLISP, Visual LISP & DCL Forum, please post in the most relevant forum.
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    835
    This sounds like a task for a dynamic block.
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,444
    Where should be located the base point?
  5. #5
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,501
    I will try to find, did something like this previously using simple input of 50,4,-25
    50 = length
    4 is number required
    -25 offset is +/- for right/left
    I will keep looking found this same idea.
    Code:
    ; copy multiple objects along x or y axis
    ; use 2x40 etc
  6. #6
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,501
    Have a look at my post here http://www.cadtutor.net/forum/showth...polyline/page3
    May though just be easier to write from scratch.
  7. #7
    Junior Member
    AutoCAD 2014
    Apr 2015
    20
    0,0 or anywhere it's not critical
  8. #8
    Junior Member
    AutoCAD 2014
    Apr 2015
    20
    Quote Originally Posted by Grrr View Post
  9. #9
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,444
    Here you go:
    Code:
    (defun C:test ( / p1 p2 off n a d f p )
      (and
        (cond
          ( (and *MtpLines* (setq p1 (getpoint "\nSpecify base point <new line>: ")))
            (mapcar '(lambda (x) (set x (cdr (assoc x *MtpLines*)))) '(d a))
            (setq p2 (polar p1 (- a (* 0.5 PI)) d))
            (and
              (setq p1 (getpoint "\nSpecify line's length: "))
              (setq p2 (getpoint "\nSpecify line's length: " p1))
        ); cond
        (not (grdraw p1 p2 1 1))
        (setq off (cond ( (progn (initget 6) (getdist (strcat "\nSpecify offset " (if (setq off (cdr (assoc 'off *MtpLines*))) (strcat "<" (rtos off 2 15) ">") "") ": "))) ) ( off )))
        (setq n (cond ( (progn (initget 6) (getint (strcat "\nSpecify number of lines " (if (setq n (cdr (assoc 'n *MtpLines*))) (strcat "<" (itoa n) ">") "") ": "))) ) ( n )))
        (or a (setq a (+ (angle p1 p2) (* 0.5 PI))))
        (or d (setq d (distance p1 p2)))
        (setq f '((p a d) (entmakex (list '(0 . "LINE") (cons 10 p) (cons 11 (polar p a d))))))
        (setq p p1)
          (redraw)
          (repeat n
            (f p (angle p1 p2) d)
            (setq p (polar p a off))
            '(( / ed pt1 pt2 dst )
              (setq ed 6.)
              (setq pt1 (polar p1 a (- ed)))
              (setq pt2 (polar p2 a (- ed)))
              (setq dst (+ (- (distance p1 p) off) (* 2. ed)))
              (f (polar pt1 (angle p1 p2) ed) a dst )
              (f (polar pt2 (angle p1 p2) (- ed)) a dst )
          (setq *MtpLines* (mapcar '(lambda (x) (cons x (eval x))) '(d a off n)))
        ); progn
      ); and
    ); defun
  10. #10
    Junior Member
    AutoCAD 2014
    Apr 2015
    20
    Thanks for code...it works some what but it's kind of confusing and does not work as i expected.. can you please change user input as follows and also Define start point to auto @ 0,0 and length going horizontally
    1. Enter total Length of the strip (ex 100")
    2. Enter Vertical offset length (both vertical line at each end) (ex 0.25")
    3. Enter horizontal offset distance (ex 5")
    4. Enter number of lines to offset (ex 10)
    I have attached the example sketch with above values... hope this info is good enough
    Thanks again
  1. Multiple user input
    By NoroZorro in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Jun 2016, 08:14 pm
  2. ESC User Input
    By Lee Chu Chu in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Jul 2014, 01:46 am
  3. Looking for user input
    By Skilbride in forum AutoCAD General
    Last Post: 23rd May 2011, 08:28 pm
  4. user input
    By salman in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th May 2010, 04:33 pm
  5. User Input:
    By tzframpton in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th May 2007, 07:12 pm
