Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Senior Member
    AutoCAD 2010
    Jun 2012
    419
    Default Convert a list to excel table
    Hello everybody,
    I have a list of about 750 points giving xyz values. I want to first convert it to an autocad table and export to excel and I am using the code given below for that. However it appears that there is a limit to number of rows. The program hangs if I remove the (princ row) line in it.
    What can be the problem?. I attach my list also herewith;
    Code:
    (defun Maketable()
    (setq n(length l))
    (setq n(- n 1))
    (command "table" 3 1 '(0 15) 2 2)
    (if (and(setq en (entlast))
    (setq myTable (vlax-EName->vla-Object en))
      (= (vla-get-ObjectName myTable) "AcDbTable")
    (setq rws (vla-Get-Rows myTable))
    (vla-InsertRows myTable rws (vla-GetRowHeight myTable (1- rws)) n)
    (vla-settext myTable 0 0 "myTable")
    (vla-settext myTable 1 0 "Xvalue")
    (vla-settext myTable 1 1 "Yvalue")
    (vla-settext myTable 1 2 "Zvalue")
    (setq row 2)
    (setq cell 0)
        (while (/= l nil)
    	(setq lstx(car l))
             (while (<= cell 2)
    	   ;(vla-settextHeight myTable row cell 0.22)
               (vla-settext myTable row cell (car lstx))
               ;(vla-setCellAlignment myTable row cell acMiddleCenter)
    	   (setq lstx(cdr lstx))
    	   (setq cell(+ 1 cell))
               (if (and (/= lstx nil) (> cell 2)) (progn (setq row(+ row 1)) (setq cell 0)))
          (princ row)
          (setq bp(getstring))
            (setq l (cdr l))
    	(setq row(+ row 1))
            (setq cell 0)
    (command "zoom" "E")
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,515
    Check your whiles and IF may be missing a bracket.
    Also why not just read the xyz straight into excel ?
    Also also why not just read the xyz file, why make a list of it seems to be an extra step.
    Just google csv to table, did you check www.lee-mac.com
    Senior Member
    AutoCAD 2010
    Jun 2012
    419
    Hi Bigal,
    Thanks for your suggestions. I was however able to get my program working by adding two lines as follows:
    Code:
    (vla-put-RegenerateTableSuppressed myTable :vlax-true)
    before defining the table title and
    Code:
    (vla-put-RegenerateTableSuppressed myTable :vlax-false)
    at the end.
    Regards,
    Aloy
    Senior Member satishrajdev's Avatar
    satishrajdev's Computer Details
    Windows 7 - 64bit
    DELL
    8 GB
    500 GB
    DELL
    Surveying
    satishrajdev's Discipline Details
    CAD Engineer
    Surveying
    Design Survey Utilities (i.e. Bathymetry & Geophysical Survey) Design of Survey Planning. Preparation of Alignment Sheets. Programming in AutoCAD.
    AutoCAD 2014
    Apr 2012
    Aamchi Mumbai, India
    442
    Try this, I've simplify you code for your better understanding
    Code:
    (defun maketable (/ tbl row)
      (if (setq tbl	(vla-addtable
    		  (vla-get-modelspace
    		    (vla-get-activedocument (vlax-get-acad-object))
    		  (vlax-3d-point '(0 15 0))
    		  (+ 2 (length l))	; ADD ROWS
    		  3			; ADD COLUMNS
    		  2			; ROW HEIGHT
    		  10			; COLUMN WIDTH
          (vla-unmergecells tbl 0 0 0 0)	; ADD THIS IF YOU WANT TO UNMERGE 1ST ROW
          (setq row 0)
          (foreach x '(0 1 2)
    	(vla-setcolumnwidth tbl x 50)
          (write-row '("X Value" "Y Value" "Z Value"))
          (foreach x l
    	(write-row x)
    (defun write-row (lst / a)     ; Write row in table
      (foreach x lst
        (if	(not a)
          (setq a 0)
          (setq a (1+ a))
        (vla-settext
          tbl
          row
          a
          (cond ((eq (type x) 'STR) x)
    	    ((eq (type x) 'REAL) (rtos x 2 3))
    	    ((not x) "-")
    	    (T (rtos x 2 2))
        (vla-setrowheight tbl row 2.)
        (vla-setcellalignment tbl row a acMiddleCenter)
      (setq row (1+ row))
    Best Regards,
    Satish Rajdev
    If you ride like there is no tomorrow... Don't worry, there won't be !!!!
    www.facebook.com/satish.rajdev
  5. #5
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,515
    A method "addrows" is just that rather than set how many rows you need, just keep reading a line of your xyz file and adding a row, again as suggested much easier to start with your data file and read that better than make a list. Just create your heading row etc and the 1st row fill that in and if more addrow.
    satishrajdev has provided a good example here is a bit simpler to create the initial table I will find the addrow code.
    Code:
    ; now do table
    (setq pt1 (vlax-3d-point (getpoint "\nPick point for top left hand of table:  ")))
    (setq numrows 3)))
    (setq numcolumns 3)
    (setq rowheight 0.2)
    (setq colwidth 150)
    (setq objtable (vla-addtable curspace pt1 numrows numcolumns rowheight colwidth))
    (vla-settext objtable 0 0 "DRAWING REGISTER")
    (vla-settext objtable 1 0 "DRAWING NUMBER")
    (vla-settext objtable 1 1 "DRAWING TITLE")
    Add a row
    Code:
    (setq rws (vla-Get-Rows objtable))
    (vla-InsertRows objtable rws (vla-GetRowHeight objtable (1- rws)) 1)   ;; 1 number of rows to add
    ; now fill in x y z
    (vla-settext objtable rws 0 (rtos x 2 2))
    (vla-settext objtable rws 1 (rtos Y 2 2))
    (vla-settext objtable rws 2 (rtos Z 2 2))
    Please post your data file.
  6. #6
    Senior Member
    AutoCAD 2010
    Jun 2012
    419
    Satishrajdev,
    Your code essentially does the same thing as mine, however the cells are too large and has the same problem of time consuming regeneration. My code as given above produce line by line as one goes on pressing any key. If I remove the (princ row) line it gets hung. But with regeneration suppressed it works fine without those two lines.
    Regards,
    Aloy.
  7. #7
    Senior Member
    AutoCAD 2010
    Jun 2012
    419
    Hi Bigal,
    Thanks. If I am not mistaken it was you who gave me the solution at an earlier occasion in this forum to suppress the regeneration to speed up on a table of about 30 rows. This one has about 750 rows. However adding row by row will not have a problem but will take too long.
    The data file is given in my post #1.
    Regards,
    Aloy
  8. #8
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,515
    I tried the direct way and interesting is the time it takes to add the values to the table. In this example I have your points but I have put an exit at the point of making a table to see whats going on, when it asks continue "Y" press any key and table will display this is reasonably quick given 724 lines. Next run answer Y I have the repeat set to 100 lines and again a bit slow. I am running on an old I3
    Oh yeah runs in paperspace and has a hard code path to test data simplifying testing will add the getfiled later.
    Code:
    ; thanks to Lee-mac for this defun
    (defun _csv->lst  (str / pos)
      (if (setq pos (vl-string-position 44 str))
        (cons (substr str 1 pos) (_csv->lst (substr str (+ pos 2))))
        (list str)))
                                            ; now do table
    (defun makexyztab
           (/ numrows numcolumns colwidth x y z doc curspace objtable k)
      (setq fo (open "C:\\BIG-AL\\lisp\\pointlist.csv" "R"))
      (setq K 1)
      (while (setq newline (read-line fo)) (setq K (+ K 1)))
      (close fo)
      (setq numrows (+ 2 K))
      (setq numcolumns 3)
      (setq colwidth 150)
      (setq doc (vla-get-activedocument (vlax-get-acad-object)))
      (setq curspace (vla-get-paperspace doc))
      (setq objtable
      (vla-settext objtable 0 0 "XYZ POINTS")
      (vla-settext objtable 1 0 "POINT X")
      (vla-settext objtable 1 1 "POINT Y")
      (vla-settext objtable 1 2 "POINT Z")
      (command "regen")
      (alert "table created")
      (if (= "Y" (strcase (getstring "Enter Y to continue")))
        (exit))
      (setq rws 2)
                                            ;(while (setq newline  (read-line fo))
      (repeat 100
        (setq lst (_csv->lst newline))
        (setq x (nth 0 lst))
        (setq y (nth 1 lst))
        (setq z (nth 2 lst))
        (vla-settext objtable rws 0 x)
        (vla-settext objtable rws 1 y)
        (vla-settext objtable rws 2 z)
        (setq rws (+ rws 1)))
      (close fo)
      (princ))
    (makexyztab)
    Next post will be a variation on method to see if I can get speed up but need num,x,y,z to test on an existing routine.
  9. #9
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,515
    Did a lot more testing and found that if I used old fashioned lines and text it creates a table in seconds all 742 entries.
    The problem seems to be in filling in the table, creating a blank table takes seconds.
    As a comparison in CIV3D imported points 10 seconds, do a table of the points about 3 seconds. All done.
    Really not sure where to go. Keep hanging my autocad seems to work if I limit the number of data read but takes forever to do. I will post the line/ text version later today.
  10. #10
    Senior Member
    AutoCAD 2010
    Jun 2012
    419
    Are you not creating a table out of the already created pointlist.csv file in your directory.
  1. Convert a simple table (exploded) to a real table.
    By CafeJr in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Nov 2015, 03:23 pm
  2. AutoCAD - Update Sheet List Table and Edit Sheet List Table Settings
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 29th Oct 2013, 07:37 pm
  3. Replies: 2
    Last Post: 24th Oct 2013, 07:42 am
  4. List of the file list (only names) copy to excel
    By wimal in forum AutoCAD General
    Last Post: 3rd Jul 2013, 11:53 am
  5. Replies: 3
    Last Post: 13th Feb 2012, 06:09 pm
