Results 1 to 7 of 7
    Super Member Bill Tillman's Avatar
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,298
    Default Placing Limits on FIND Command
    We use lots of blocks here and one of them is a bubble with some text in it which identifies an assembly. When I use the FIND command and search for something like WS-4, it finds them but it also finds WS-4A, WS-4B, etc...I have selected the "Find whole words only" but then it won't find anything even though without this setting it finds 114 objects.
    It's deja vu, all over again.
    Super Member
    AutoCAD 2010
    Dec 2010
    1,223
    Quote Originally Posted by Bill Tillman View Post
    You can try the search interface where you can be more specific with your search function.
    Sent from my Redmi Note 4X using Tapatalk
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,511
    Did you have a look at Lee's version of find ? http://www.lee-mac.com/bfind.html
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,298
    Quote Originally Posted by BIGAL View Post
    Thanks BIGAL, I'll give that a look. Trouble is this client uses LT and that means no LISP. Maybe we should develop a new version of LISP and call it NoLISP4LT...LOL!
  5. #5
    Senior Member lrm's Avatar
    lrm's Computer Details
    Windows 7 64-bit
    16 GB
    Education
    lrm's Discipline Details
    Teacher, AEC and mechanical
    Education
    Civil and Mechanical
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    375
    Try using the FILTER command. For example:
    After giving the filter command specify text as the Select Filter. Next click Add Selected Object and click one of the WS-5 instances then delete the line Text Position... ( you do not want to limit the selection to text with exactly the same position). You can name this filter if you plan to re-use it. Click Apply and give a bis select window or type ALL. Only "WS-5" text will be selected.
  6. #6
    AutoCAD 2013
    Nov 2011
    6,045
    Quote Originally Posted by lrm View Post
    Try using assuming that LeeMac's BFind (which is totally epic) won't do it for you. the FILTER command. For example:
    +1 Absolutely the way to go,
    Filter is incredibly powerful, really dives deep; kind of tedious to set up, but very precise.
  7. #7
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,084
    I moved your thread to the AutoCAD LT Forum since all solutions need to be usable in LT.
  1. Placing text in box and 'tl' command
    By L-P in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 16th Nov 2017, 04:10 pm
  2. Find command
    By gpd in forum AutoCAD General
    Last Post: 15th Dec 2011, 12:00 pm
  3. FIND command without dialog box?
    By NoelStalker in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Nov 2009, 03:12 pm
  4. Cannot find Command???
    By MikeP in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Jul 2008, 05:24 pm
  5. LIMITS: Need some help with setting Acad limits with VBA
    By mlowe in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Dec 2005, 03:05 pm
