Placing Limits on FIND Command
Bill Tillman
We use lots of blocks here and one of them is a bubble with some text in it which identifies an assembly. When I use the FIND command and search for something like WS-4, it finds them but it also finds WS-4A, WS-4B, etc...I have selected the "Find whole words only" but then it won't find anything even though without this setting it finds 114 objects.
You can try the search interface where you can be more specific with your search function.
Sent from my Redmi Note 4X using Tapatalk
Try using the FILTER command. For example:
After giving the filter command specify text as the Select Filter. Next click Add Selected Object and click one of the WS-5 instances then delete the line Text Position... ( you do not want to limit the selection to text with exactly the same position). You can name this filter if you plan to re-use it. Click Apply and give a bis select window or type ALL. Only "WS-5" text will be selected.
Try using assuming that LeeMac's BFind (which is totally epic) won't do it for you. the FILTER command. For example:
+1 Absolutely the way to go,
Filter is incredibly powerful, really dives deep; kind of tedious to set up, but very precise.
