Results 1 to 8 of 8
    Senior Member
    Construction
    wimal's Discipline Details
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    488
    Default Why the first code not working
    Code:
    (setq ss nil)
    (if (and (not (initget "Lap"))
              (setq ss (entsel "\nSelect fixed line [Lap length] : ")))
              (if (= "Lap" ss)(progn
               (setq pick "Y")
    	   (setq ss (entsel "\nSelect fixed line  : "))
    2nd code is working
    Code:
    (setq ss nil)
              (setq ss (getpoint "\npick point [Lap length] : ")))
               (setq pick "Y")
    	   (setq ss (getpoint "\npick point  : "))
    Senior Member
    Civil
    Aftertouch's Discipline Details
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    286
    I have never used initget with entsel or getpoint...
    What are you trying to achieve? Im sure there is a simpler way...
    Senior Member
    Construction
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    488
    Quote Originally Posted by Aftertouch View Post
    I need to allow to user to set value of LAP , if user required. Default value is set to 500
    Senior Member
    Civil
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    286
    And you want the user to be able to set the value of LAP... by selecting an entitie and get its length?
    so 'LAP' is 500 OR the length of a selected line?
  5. #5
    Super Member
    not applicable
    Jun 2016
    669
    Maybe the issue is related to the first letter of the keyword. 'L' has a special meaning when selecting entities: L=Last entity.
    BricsCAD 18
  6. #6
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,506
    Here is an example that checks what is picked. Includes L for last which is accepted by entsel.
    Code:
    (defun c:aaa ( / obj)
    (while
    (setq obj (vlax-ename->vla-object (car (entsel "\nPick objects L for last object"))))
    (cond
    ((= (vla-get-objectname obj) "AcDbLine")(setq len (vla-get-length obj)))
    ((= (vla-get-objectname obj) "AcDbArc")(setq len (vla-get-Arclength obj)))
    ((= (vla-get-objectname obj) "AcDbCircle")(setq len (vla-get-Circumference obj)))
    ((= (vla-get-objectname obj) "AcDbPolyline")(setq len (vla-get-length obj)))
    (if (>  len 0.0)
    (alert (strcat "length is " (rtos len 2 2)))
    (alert "object has no direct length")
    (setq len nil)
  7. #7
    Senior Member satishrajdev's Avatar
    satishrajdev's Computer Details
    Windows 7 - 64bit
    DELL
    8 GB
    500 GB
    DELL
    Surveying
    satishrajdev's Discipline Details
    CAD Engineer
    Surveying
    Design Survey Utilities (i.e. Bathymetry & Geophysical Survey) Design of Survey Planning. Preparation of Alignment Sheets. Programming in AutoCAD.
    AutoCAD 2014
    Apr 2012
    Aamchi Mumbai, India
    442
    Quote Originally Posted by Roy_043 View Post
    You are right, Its happening because of L stands for Last entity.
    Check out this :
    Code:
    (setq ss nil)
    (if (and (not (initget "LAP"))
    	 (setq ss (entsel "\nSelect fixed line [LAP length] : "))
      (if (= "LAP" ss)
          (setq pick "Y")
    Best Regards,
    Satish Rajdev
    If you ride like there is no tomorrow... Don't worry, there won't be !!!!
    www.facebook.com/satish.rajdev
  8. #8
    Senior Member
    Construction
    cadoperator
    Construction
    AutoCAD 2016
    Oct 2011
    sri lanka
    488
    Yes my friend ,it was the problem. Thanks a lot.
  1. Autolisp code for working with Imaginary numbers
    By symysgames in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Oct 2016, 10:48 pm
  2. Copy and paste autolisp code not working?
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 28th Jan 2016, 02:30 pm
  3. lisp code not working
    By mhmnibras in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Mar 2015, 07:57 pm
  4. saveas code not working
    By WPerciful in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Feb 2015, 01:48 pm
  5. Cond.. code is not working
    By bijoyvm in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th May 2012, 12:43 pm
