Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,506
    dnovember99 did you look at what I posted it does lots more than just log time. I use a cut down version every day. It records every project individually from day 1.
    Code:
    cut down report
    START TIME of report entry .... 2018.Jan.05  09:54:53
    END TIME of report entry ...... 2018.Jan.05  10:05:45
    Total period ............................... 00:10:52
    FILENAME:           2012161-PF.dwg
    DIRECTORY:          \\XXXX.l\2012 Projects\2012161\Design\
    LAST SAVE:          2018.Jan.05  10:05:40
    TOTAL EDITING TIME: 397:56:44
    LOGGED USER:        BIGAL
    START TIME of report entry .... 2018.Jan.06  10:17:53
    END TIME of report entry ...... 2018.Jan.06  10:30:34
    Total period ............................... 00:12:41
    LAST SAVE:          2018.Jan.05  10:30:29
    TOTAL EDITING TIME: 398:09:42
    LOGGED USER:        BIGAL
    START TIME of report entry .... 2018.Jan.07  10:31:01
    END TIME of report entry ...... 2018.Jan.07  10:56:51
    Total period ............................... 00:25:50
  2. #12
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,447
    Quote Originally Posted by Lee Mac View Post
    IMO, calling pstxt with an empty string is more useful than supplying nil - consider that getstring returns an empty string on null input.
    Well that pstxt its used, depending on the case(application) - but I agree that it doesn't suit well with getstring, hence OP's problem.
    I was using it somewhere to look for a certain attrib values, then consider if they are valid to construct a main string.
    Or say something like (I know this example could be written better) :
    Code:
    (defun picktext ( msg / e r )
      (and
        (setq e (car (entsel msg))) ; user is allowed to miss-pick
        (setq r (cdr (assoc 1 (entget e))))
      r
    (pstxt
      (picktext "\nPrefix: ")
      (picktext "\nMain Text: ")
      (picktext "\nSuffix: ")
  1. Add symbols to existing text lisp
    By structo in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Dec 2016, 07:06 am
  2. How to add attribute text an existing block
    By RRS1987 in forum AutoCAD Beginners' Area
    Last Post: 14th Feb 2015, 04:01 pm
  3. Routine to add modified text below existing text (copy/replace?)...
    By lamensterms in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Jun 2011, 08:44 am
  4. Adding additional text to Dimension Text Override
    By RoguePiper in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Aug 2010, 07:17 pm
  5. Change Existing Text to Number?
    By AQucsaiJr in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Jul 2009, 12:30 pm
