Results 1 to 3 of 3
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    Idea M2P and FROM Command Modifiers Using LSP
    Hello, is there a way to combine the move command with the M2P or FROM command modifiers using LISP?
    I would want these to be two separate commands.
    Ideally I would like to program F1 to do _m2p during an active line command and F2 to do from during an active line command... but I'll settle for a lisp that combines each with the move command since I'll be doing that most frequently.
    Thank you in advance!
    P.S. here is code that will draw a line starting at M2P.. sort of a start.
    (defun c:v (/ p1 p2 mid)
    (if (and (setq p1 (getpoint "\nSpecify 1st point of MID :"))
    (setq p2 (getpoint "\nSpecify 2nd point of MID :" p1))
    (setq mid (mapcar '(lambda (q p) (/ (+ q p) 2.)) p1 p2))
    (command "_.pline" "_none" mid)
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,812
    Maybe some thing like this need to autoload.
    Code:
    (defun c:2 (/ p1 p2 mid)
    (setq p2 (getpoint "\nSpecify 2nd point of MID :" p1)))
    To run say LINE '2 pick 2pts next point etc '2 as required. Using a none for snaps means you dont find the ends for the half point. Looking into 1/4 etc the other thing to look at is CAL it has a number of functions very few people use it but it can do a lot of this type of thing.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,157
    Please read the Code Posting Guidelines and edit your Code to be included in Code Tags not Quote Tags.[CODE]Your Code Here[/CODE] =
    Code:
    Your Code Here
  1. Revit Modifiers
    By addesigns in forum Revit General
    Last Post: 21st Sep 2015, 03:44 pm
  2. Script Issues: Not performing correct command or skipping command.
    By asad112 in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 23rd Sep 2012, 02:16 am
  3. Replies: 1
    Last Post: 4th Nov 2011, 01:54 pm
  4. TEXT command made in MSexcel fail to execute in command line Autocad 2006 and higher
    By ctdlc888 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Sep 2011, 04:05 am
Tags for this Thread
