Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: scale problem
    Forum Newbie
    Architectural
    AutoCAD 2014
    Feb 2018
    2
    Default scale problem
    model space drawing is turned block and is scaled up,
    while my layout scale is showing drawing in 1:1.
    How to get modelspace drawing back to 1:1 scale?
    anyone plese help,kindly find the attachment
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,857
    Is there at least one object that you know the true size of? If so you should be able to scale the drawing correctly.
    For future consideration. Actual .dwg files are better than image files. If the file size is too large to upload here you can use a file sharing website like DropBox then post a link to the file here.
    I'm retired now.....not dead. I have a few working brain cells left.
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,227
    In my work, I like to incorporate architectural drawings as xrefs. Either way, block or xref, you can define the X and Y scales in the Properties for the object. That will make your block actual size in model space, which is something that makes life easier for you.
    Once you've done that, you can adjust the scale of your viewport. If your drawing doesn't have the scale you want, you'll have to edit your scale list.
    Welcome to the forum. If this doesn't resolve your issue, please give us more information.
    breaking AutoCAD on a regular basis since 1991
    Forum Newbie
    Architectural
    AutoCAD 2014
    Feb 2018
    2
    Thanks a lot for the suggestions,i have uploaded the file.You see the lift shaft wall,the thickness of the lift shaft wall is 200 mm for reference.
  5. #5
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,174
    Nothing is attached, and for information the biggest known size usually produces the best results, so rather than the thickness of a wall you should look for the longest known wall length in a building. And when you have a known size use the scale command select everything in the drawing that needs scaling. When you start the command it will ask for a base point, pick one end of the object that you know the size of, then the next prompt from Autocad will ask you for a scale factor or a reference, pick the reference option, now pick the two endpoints of the object and after that input the new size just by typing the numbers and everything will be scaled accordingly. If you do something wrong you can always undo and try again, or you might decide that the base point should be somewhere else, you can still use the reference option of scale.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  6. #6
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,794
    Reading post 1 again block is at scale so rescale 1/current scale of block then explode. 2nd clue layout is at 1:1 no its at a scale open the viewports tool bar click inside viewport a number will appear in the toolbar box, thats the scaling factor, 3rd if the viewport is 1:1 then they have scaled the title block to suit what a mess and probably use fit when plotting.
    Agree with Steven-g use the overall length of the building to rescale.
    Really do need a dwg to work it out.
  7. #7
    Super Member
    Ski_Me's Computer Details
    DELL (why oh lord must I suffer)
    Electrical
    Ski_Me's Discipline Details
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    643
    Did anybody notice that the OP has multiple title blocks on 1 layout. This drawing is an unmitigated disaster. If I was the project manager for this building I would refuse to do anything until I could get a proper set of drawings from a qualified firm.
  8. #8
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,174
    Quote Originally Posted by Ski_Me View Post
    Thats common practice, at least I see it regularly from Architects here. I'm not saying it's good practice but it is a standard way of working.
  9. #9
    Super Member
    Electrical
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    643
    I have never received drawings from an Architect that only had one layout for a building with multiple title blocks. It just seems that the OP scaled the model space drawing to fit the layout. We don't know how many times he has scaled the model space drawing. I doubt the OP has any idea of the longest wall that he has in the drawing. This is a square one situation meaning start at square one, the accuracy of the drawing has been compromised. I would not want to be the person that has to layout the walls on this building from these drawings. There are some things you cannot recover from in AutoCAD this could be of them.
  10. #10
    Windows 10
    Architectural
    Civil Drafter
    Architectural
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,227
    It's possible that the multiple plans are separate floors of the same building. The multiple title blocks, though, that's just wrong.
  1. Lt Scale Problem
    By stevsmith in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 19th Aug 2009, 01:31 pm
  2. SCALE problem..help me please !
    By CAD-LOVER0208 in forum AutoCAD General
    Last Post: 21st Oct 2008, 04:57 pm
