Results 1 to 4 of 4
    Senior Member
    AutoCAD 2015
    Jan 2015
    126
    Default Draw lines and circles with some rules
    Hi guys!
    I've wrote this lisp in order to draw these circles + lines in a fasted way.
    As you can see it doesn't work very good with the vertical edge of 30cm, but it works if I put 60cm..
    The program asks me the following:
    1. number of lines
    2. number of circles for each line
    3. 2 points where to draw them
    4. side of the line I've just draw with the 2 points
    Code:
    (defun C:pu (/ linea)
      (setq n1 (getint "\nQuante legature? ") ;how many lines
            n2 (getint "\nQuante file? ")) ; how many circles for each line
      (command "_Line" pause pause "")
      (setq linea (entlast))
      ;(command "_divide" linea (* 2 n1))
      (setq p1 (cdr (assoc 10 (entget linea)))
          p2 (cdr (assoc 11 (entget linea)))
            dist (/ (distance p1 p2) (* 2 n1)))
      (entdel linea)
      (setq ref (getpoint))
      (setq passo 0.16
            dist1 0.08
            n 0
            j 1
      (IF (> (nth 0 p1) (nth 0 p2))
             (setq swap p2
                   p2 p1
                   p1 swap)
      (IF (> (nth 1 p1) (nth 1 p2))
             (setq swap p2
                   p2 p1
                   p1 swap)
    ;Horizzontal
      (COND ((= (fix (nth 1 p1)) (fix (nth 1 p2)))
    (IF (< (nth 1 ref) (nth 1 p1))
             (setq passo (* passo -1)
              dist1 (* dist1 -1)
           (while (< n  n1 )
             (setq i 1)
             (Entmake (list (cons 0 "CIRCLE")
                          (cons 8 "SCHÖCK_BOLE")
                          (cons 10 (list (+ (nth 0 p1) (* j dist)) (+ (nth 1 p1) dist1) (nth 2 p1)))
                          (cons 40 0.035)
                          (cons 62 3)
        (while (< i n2)
                          (cons 10 (list (+ (nth 0 p1) (* j dist)) (+ (nth 1 p1) dist1 (* i passo)) (nth 2 p1)))
                          (cons 40 0.035)
                          (cons 62 3)
              (setq i (+ i 1))
             (entmake (list (cons 0 "LINE")
                            (Cons 8 "SCHÖCK_BOLE")
                            (cons 11 (list (+ (nth 0 p1) (* j dist)) (+ (nth 1 p1) dist1 (* (- i 1) passo)) (nth 2 p1)))
                            (cons 62 3)
             (setq j (+ j 2)
                   n (+ n 1))
            ;VERTICAL
            ((= (fix (nth 0 p1)) (fix (nth 0 p2)))
        (IF (< (nth 0 ref) (nth 0 p1))
              dist1 (* dist1 -1)
             (while (< n  n1 )
             (setq i 1)
                          (cons 10 (list  (+ (nth 0 p1) dist1) (+ (nth 1 p1) (* j dist)) (nth 2 p1)))
                          (cons 40 0.035)
                          (cons 62 3)
        (while (< i n2)
                          (cons 10 (list  (+ (nth 0 p1) dist1 (* i passo)) (+ (nth 1 p1) (* j dist)) (nth 2 p1)))
                          (cons 40 0.035)
                          (cons 62 3)
              (setq i (+ i 1))
                            (cons 11 (list  (+ (nth 0 p1) dist1 (* (- i 1) passo)) (+ (nth 1 p1) (* j dist)) (nth 2 p1)))
                            (cons 62 3)
             (setq j (+ j 2)
                   n (+ n 1))
    How can I handle non vertical/horizontal lines?
    How can I draw in the corner as well?
    Thanks!
    Dennis
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,461
    Use the polar function to calculate the position of points, and the angle function to calculate the angle between two given points.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,175
    One suggestion in your code you repeat the entmake multiple times this could exist maybe twice line,circle as you can use a defun that you pass the variables to, this is a standard type of thing in programming to not write bits of code repeatedly.
    Code:
    (defun ML:Makeline (lay pt1 pt2 /  )
           (Cons 8 Lay)
           (cons 10 pt1)
           (cons 11 pt2)
           (cons 62 3)
    ; put at start
    (setq clay "SCHÖCK_BOLE")
    ; example
    (setq p1 (list  (+ (nth 0 p1) dist1) (+ (nth 1 p1) (* j dist)) (nth 2 p1)))
    (setq p2 (list (+ (nth 0 p1) (* j dist)) (+ (nth 1 p1) dist1 (* (- i 1) passo)) (nth 2 p1)))
    (ML:Makeline clay p1 p2)
    Senior Member
    AutoCAD 2015
    Jan 2015
    126
    Thank you guys for your help!
    Yes I should learn to code a little bit better my code looks always like a mess..
    I'll try to fix it!
    See you soon!
    Dennis
    Dennis
  1. Replies: 0
    Last Post: 15th Jul 2011, 08:30 pm
  2. Draw A Line With 2 Circles
    By JONTHEPOPE in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Aug 2008, 06:10 pm
  3. Need to Draw Circles at all endpoints of and object
    By MikeP in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jun 2008, 03:20 pm
  4. Going in circles trying to draw an arc in 3D
    By Gerhard van Eeden in forum AutoCAD Beginners' Area
    Last Post: 5th Jun 2008, 05:38 pm
  5. draw circles through points
    By motee-z in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Jul 2006, 05:50 am
