Results 1 to 2 of 2
    Forum Newbie
    AutoCAD 2016
    Oct 2016
    5
    Default Extrude Xref file
    Hi,
    I want to attach an Xref file into a drawing (which contains a region), and use it for extrude operation.
    After doing this, if I am modifying the region from the original dwg. file it will also be updated in the file with extrude (as Xref).
    Is this possible with VBA? I am new to it and I find it very hard to write the code (if needed) and I don't know any other way to do it.
    Thank you in advance,
    Forum Newbie
    AutoCAD 2016
    Oct 2016
    5
    Anyone? At least will be helpful to know if this solution is at least possible
  1. Extrude, Extrude Faces, Union
    By joao56777 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 30th Dec 2016, 08:52 am
  2. See in which file a dwg is inserted as xref?
    By Lineke in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Apr 2014, 08:37 am
  3. cannot extrude into solid but gives me surface extrude
    By amard_burn in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Nov 2013, 05:31 am
  4. Xref File name
    By ranassar in forum CAD Management
    Last Post: 30th Oct 2008, 02:00 pm
  5. Xref File name
    Last Post: 30th Oct 2008, 01:59 pm
