Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Junior Member
    Manufacture
    AutoCAD 2014
    Oct 2017
    21
    Default VLA Create Block Definition and Add Entity...
    I seem to be stuck..
    Combed through all the documentation plus google searches...
    What am I missing?
    Can't seem to add object to my block definition...
    vl-load-com loaded
    ActiveDocument loaded...
    Acad-Object loaded...
    Code:
    (setq fax (vlax-ename->vla-object far)) ;returns #<VLA-OBJECT IAcadSolid 0000024d51846d98>
    (setq blk (vla-get-Blocks doc)) ;returns #<VLA-OBJECT IAcadBlocks 0000024d3ecb3a38>
    (setq fab (vla-Add blk fpa "_ClosedFilled")) ;returns #<VLA-OBJECT IAcadBlock 0000024d37310cf8>
    (setq fax (vla-CopyObjects doc fax fab)) ;returns nothing!!!!????
    Your thoughts?............
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,141
    Junior Member
    Manufacture
    AutoCAD 2014
    Oct 2017
    21
    I followed your link BIGAL... all the way to Lee Mac's "AddObjectstoBlock" lisp.... I see similar syntax in his routine:
    (vla-CopyObjects (ActiveDoc variable) (list of objects to add) (block reference name))
    I still don't get why mine won't work... I'm thinking maybe I have either the entity variable or the block reference variable in an improper form... maybe i cannot add the single entity i get from "vlax-ename->vla-object x"... maybe it expects an selection set array... maybe it expects some other info before it can add the object.... i don't know...
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2015
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,124
    Hi,
    To avoid the safearray just use the vlax-invoke instead besides that you need to have your vla-object(s) as a list.
    Code:
    (vlax-invoke doc 'CopyObjects (list fax) fab)
  5. #5
    Junior Member
    Manufacture
    AutoCAD 2014
    Oct 2017
    21
    oooh! wow... I spent the whole day spinning my wheels.. Thanks Tharwat... I'll try it out and report back....
    funny thing is I tried this method as well but without list.. same nil..
    So just to be clear though... the first method does require a safearray of objects? Also can a safearray contain a single object? just for future reference...
    Thank you both!
  6. #6
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,124
    Quote Originally Posted by eimimitu View Post
    You are welcome.
    Certainly, have a look at the following for your reference that contains a single object ( and not married one. ).
    Code:
    (setq safe (vlax-make-safearray vlax-vbObject '(0 . 0)))
    (vlax-safearray-put-element safe 0 fax)
    (vla-CopyObjects doc safe fab)
  7. #7
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,280
    I always forget that the methods sometimes require safearrays...
    Makes me think does a variant type of argument is required anywhere? So one would be forced to use vlax-make-variant function.
  8. #8
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,455
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  9. #9
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,280
    Quote Originally Posted by Lee Mac View Post
    Veery nice, in conjunction with this, one could store selection sets to be previewed in DCL.
  10. #10
    Junior Member
    Manufacture
    AutoCAD 2014
    Oct 2017
    21
    good (- 3 2) Tharwat Some objects just aren't ready to settle down...
    It worked... freakin' brillant! TY!
  1. How to create boundary box with spline entity?
    By kwwong6 in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Mar 2015, 10:32 am
  2. create block with N last entity
    By metaldan in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Feb 2014, 03:12 am
  3. Slicing in 3D wants me to create a block definition?
    By TED Jordan in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Jul 2013, 04:46 pm
  4. Block Definition
    By criehle in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jul 2009, 06:47 pm
  5. Create image entity using entmake?
    By Treddin in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jul 2008, 06:49 pm
Tags for this Thread
