+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
  1. #1
    Full Member
    Discipline
    Manufacture
    Using
    AutoCAD 2014
    Join Date
    Oct 2017
    Posts
    39
    Default VLA Create Block Definition and Add Entity...
    I seem to be stuck..
    Combed through all the documentation plus google searches...
    What am I missing?
    Can't seem to add object to my block definition...
    vl-load-com loaded
    ActiveDocument loaded...
    Acad-Object loaded...
    Code:
    (setq fax (vlax-ename->vla-object far)) ;returns #<VLA-OBJECT IAcadSolid 0000024d51846d98>
    (setq blk (vla-get-Blocks doc)) ;returns #<VLA-OBJECT IAcadBlocks 0000024d3ecb3a38>
    (setq fab (vla-Add blk fpa "_ClosedFilled")) ;returns #<VLA-OBJECT IAcadBlock 0000024d37310cf8>
    (setq fax (vla-CopyObjects doc fax fab)) ;returns nothing!!!!????
    Your thoughts?............
  2. #2
    Quantum Mechanic BIGAL's Avatar
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,812
  3. #3
    Full Member
    Discipline
    Manufacture
    Using
    AutoCAD 2014
    Join Date
    Oct 2017
    Posts
    39
    Default
    I followed your link BIGAL... all the way to Lee Mac's "AddObjectstoBlock" lisp.... I see similar syntax in his routine:
    (vla-CopyObjects (ActiveDoc variable) (list of objects to add) (block reference name))
    I still don't get why mine won't work... I'm thinking maybe I have either the entity variable or the block reference variable in an improper form... maybe i cannot add the single entity i get from "vlax-ename->vla-object x"... maybe it expects an selection set array... maybe it expects some other info before it can add the object.... i don't know...
  4. #4
    Luminous Being Tharwat's Avatar
    Discipline
    Mechanical
    Tharwat's Discipline Details
    Occupation
    MEP AutoCAD Draughtsman
    Discipline
    Mechanical
    Details
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    Using
    AutoCAD 2017
    Join Date
    Oct 2009
    Location
    Great Syria , Living in Abu Dhabi
    Posts
    6,271
    Default
    Hi,
    To avoid the safearray just use the vlax-invoke instead besides that you need to have your vla-object(s) as a list.
    Code:
    (vlax-invoke doc 'CopyObjects (list fax) fab)
  5. #5
    Full Member
    Discipline
    Manufacture
    Using
    AutoCAD 2014
    Join Date
    Oct 2017
    Posts
    39
    Default
    oooh! wow... I spent the whole day spinning my wheels.. Thanks Tharwat... I'll try it out and report back....
    funny thing is I tried this method as well but without list.. same nil..
    So just to be clear though... the first method does require a safearray of objects? Also can a safearray contain a single object? just for future reference...
    Thank you both!
  6. #6
    Discipline
    Mechanical
    Occupation
    Discipline
    Mechanical
    Details
    Using
    AutoCAD 2017
    Join Date
    Oct 2009
    Location
    Posts
    6,271
    Default
    Quote Originally Posted by eimimitu View Post
    You are welcome.
    Certainly, have a look at the following for your reference that contains a single object ( and not married one. ).
    Code:
    (setq safe (vlax-make-safearray vlax-vbObject '(0 . 0)))
    (vlax-safearray-put-element safe 0 fax)
    (vla-CopyObjects doc safe fab)
  7. #7
    Super Member
    Discipline
    Multi-disciplinary
    Using
    AutoCAD 2015
    Join Date
    Nov 2013
    Posts
    1,490
    Default
    I always forget that the methods sometimes require safearrays...
    Makes me think does a variant type of argument is required anywhere? So one would be forced to use vlax-make-variant function.
  8. #8
    Quantum Mechanic Lee Mac's Avatar
    Computer Details
    Lee Mac's Computer Details
    Operating System:
    Win 7 Pro / Win 10 Pro / Linux Mint
    Discipline
    Multi-disciplinary
    Lee Mac's Discipline Details
    Discipline
    Multi-disciplinary
    Details
    Custom Programming / Software Customisation
    Using
    AutoCAD 2018
    Join Date
    Aug 2008
    Location
    London, England
    Posts
    19,570
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    With Mathematics there is the possibility of perfect rigour, so why settle for less?
  9. #9
    Super Member
    Discipline
    Multi-disciplinary
    Using
    AutoCAD 2015
    Join Date
    Nov 2013
    Posts
    1,490
    Default
    Quote Originally Posted by Lee Mac View Post
    Veery nice, in conjunction with this, one could store selection sets to be previewed in DCL.
  10. #10
    Full Member
    Discipline
    Manufacture
    Using
    AutoCAD 2014
    Join Date
    Oct 2017
    Posts
    39
    Default
    good (- 3 2) Tharwat Some objects just aren't ready to settle down...
    It worked... freakin' brillant! TY!
Similar Threads
  1. How to create boundary box with spline entity?
    By kwwong6 in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Mar 2015, 10:32 am
  2. create block with N last entity
    By metaldan in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Feb 2014, 03:12 am
  3. Slicing in 3D wants me to create a block definition?
    By TED Jordan in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Jul 2013, 04:46 pm
  4. Block Definition
    By criehle in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jul 2009, 06:47 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
