Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2015
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,124
    Quote Originally Posted by eimimitu View Post
    good (- 3 2) Tharwat Some objects just aren't ready to settle down...
    It worked... freakin' brillant! TY!
    You are welcome anytime.
  2. #12
    Junior Member
    Manufacture
    AutoCAD 2014
    Oct 2017
    21
    this is what I ended up with after reviewing some of the links provided:
    Code:
    (setq sav (vlax-ename->vla-object sar))
    (vla-Rotate sav (setq spa (vlax-3d-point spo)) (- (dtr 180.0) (angle spo tpo)))
    (vlax-invoke doc 'CopyObjects (list sav) (vla-Add (vla-get-Blocks doc) spa "_ClosedFilled"))
    (vla-delete sav)
    (setq sax (vla-InsertBlock (if (= (getvar 'tilemode) 1) (vla-get-ModelSpace doc) (vla-get-PaperSpace doc)) spa "_ClosedFilled" 1.0 1.0 1.0 0.0))
    Thanks everyone for your input....
    That change block name with DCL preview is pretty sweet
  1. How to create boundary box with spline entity?
    By kwwong6 in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Mar 2015, 10:32 am
  2. create block with N last entity
    By metaldan in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Feb 2014, 03:12 am
  3. Slicing in 3D wants me to create a block definition?
    By TED Jordan in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Jul 2013, 04:46 pm
  4. Block Definition
    By criehle in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jul 2009, 06:47 pm
  5. Create image entity using entmake?
    By Treddin in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jul 2008, 06:49 pm
Tags for this Thread
