Vault 2018 layer values reset when renaming Xrefs through vault
SunnyTurtle
Hi Guys I had an issue with Vault 2018 (RTM) | Build 23.0.76.0 that i wanted to make people aware of.
So I renamed Xrefs for some drawings. So I renamed Xrefs
I did this though the rename wizard in vault. This worked without issue.
But when I went to work in the drawing all the Xref layer setting had reset to match xref. Same as if VISRETAIN was set to 0 and you reloaded.
After some consulting a forum I discover this was a known Issue with Vault 2018 and had be fixed in Vault Version 2018.2 | Build 23.2.3.0
https://forums.autodesk.com/t5/vault-forum/vault-removes-xref-layer-overrides-when-renaming-xrefs/m-p/7761413
I am currently using Version Vault 2018 (RTM) | Build 23.0.76.0
The solution is to get the latest version of Vault. but i am unable to do this at this time.
So I came up with a work around
So basically i discovered that the rename actually take place as you do a get on the drawings. So you can be quick and get the file before it rename/repaths the xrefs in the drawing.
First you need to prepare a .bat file that loops like crazy
@echo off
cls
:start
robocopy "drawing folder not xref folder" "copy folder" /XA:R /w:1 /r:1 /MINAGE:1
REM pause
goto start
This will give you the files before they are renamed in the copy folder
You then can rename/repath the old fashioned way.
I used this lisp
(defun XrefRenameAndRepath (OldName NewPath NewName /)
(if (ssget "X" (list
		  (cons 0 "INSERT")
		  (cons 2 OldName)
(command "-XREF" "P" OldName (STRCAT NewPath NewName))
(command "-RENAME" "B" OldName NewName)
;(command "-XREF" "R" OldName)
(princ (strcat "\n" OldName " not found"))
) ;if
) ;XrefRenameAndRepath
(princ "\nsubFunction Rename all and repath Xref loaded: (XrefRenameAndRepath) ")(princ)
This code to batch on all drawings as a script or lisp
(XREFRENAMEANDREPATH oldName newNath newname)
Then checkout the drawings replace them with the copys and Checkin.
Just a quick write up of a challenging problem for me. Would love to here if anyone else is having the same problem
Edited by SunnyTurtle
didn't finish
