Results 1 to 3 of 3
Thread: Publishing
    Super Member Bill Tillman's Avatar
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,304
    Default Publishing
    I have limited experience with the PUBLISH command relying mostly on default settings. This morning I have 120 CAD files from and architect that I need to publish to PDF. Each CAD file has only the generic settings in the page setup. I need each of the 120 pages to use the same settings for page setup, size and plot style.
    The first hurdle I face is that each CAD file contains a single layout tab titled "Sheet" so as I add all of them to the publish window I have to manually change the name of each one on the fly. Is there a way to speed this up?
    I setup a new page layout and then select all the pages and assign this page layout to all of them. But this is rather laborious and I'm hoping there is a faster way to handle this. These files are from one of the large Architect firms who sgall remain anonymous, but I got to believe that they have some way of publishing all 120 sheets without so much manual setup each time.
    It's deja vu, all over again.
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,608
    I have not tested this lately, but I wonder if you could add all of those sheets to a new Sheet Set, then publish from there using a Page Setup Override...?
    http://heidihewett.blogs.com/aboveth...appen_s_1.html
    R.K. McSwain
    CAD Panacea | twitter
    Senior Member
    AutoCAD 2009
    Oct 2012
    357
    Attach a sample file .dwg
    We need to look at your title block.
    Software development
    Batch printing drawings from model and printing PDF to different printers
    https://www.kdmsoft.net
  1. Publishing
    By DonovanPorter in forum AutoCAD Beginners' Area
    Last Post: 20th Aug 2010, 11:56 am
  2. Publishing to web
    By Ubatoid in forum SolidWorks
    Last Post: 2nd May 2010, 08:44 pm
  3. Publishing to the Web
    By CADswoop in forum AutoCAD General
    Last Post: 17th Aug 2009, 06:30 pm
