Bill Tillman Posted February 9, 2018 Share Posted February 9, 2018 I have limited experience with the PUBLISH command relying mostly on default settings. This morning I have 120 CAD files from and architect that I need to publish to PDF. Each CAD file has only the generic settings in the page setup. I need each of the 120 pages to use the same settings for page setup, size and plot style. The first hurdle I face is that each CAD file contains a single layout tab titled "Sheet" so as I add all of them to the publish window I have to manually change the name of each one on the fly. Is there a way to speed this up? I setup a new page layout and then select all the pages and assign this page layout to all of them. But this is rather laborious and I'm hoping there is a faster way to handle this. These files are from one of the large Architect firms who sgall remain anonymous, but I got to believe that they have some way of publishing all 120 sheets without so much manual setup each time. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted February 9, 2018 Share Posted February 9, 2018 I have not tested this lately, but I wonder if you could add all of those sheets to a new Sheet Set, then publish from there using a Page Setup Override...? http://heidihewett.blogs.com/abovetheclouds/2006/01/sheets_happen_s_1.html Quote Link to comment Share on other sites More sharing options...
maratovich Posted February 9, 2018 Share Posted February 9, 2018 Attach a sample file .dwg We need to look at your title block. Quote Link to comment Share on other sites More sharing options...
