+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    Full Member Kowal's Avatar
    Using
    Civil 3D 2014
    Join Date
    Apr 2013
    Posts
    84
    Default DCL alignment column
    I am trying to format the DCL window.
    Code:
      : text {
      label = "Test DCL.";
      alignment = centered;
      : row {
      : boxed_column {
      width = 10;
      alignment = left;
      fixed_width = true;
      : text {
      label = "1.";
      : text {
      label = "2.";
      alignment = left;
        : boxed_column {
        width = 20;
      fixed_width = true;
      : text {
      label = "3.";
      alignment = right;
      : text {
      label = "4.";
      alignment = left;
      : row {
          : edit_box {
        label = "Test:";
          key = "Edit4";//Edit1$ from lsp file
          edit_width = 150.0;
          alignment = left;
          fixed_width = true;
    The window looks like this:
    How to move the column to the left does not change its width.
    As in the picture below.
  2. #2
    Quantum Mechanic Lee Mac's Avatar
    Computer Details
    Lee Mac's Computer Details
    Operating System:
    Win 7 Pro / Win 10 Pro / Linux Mint
    Discipline
    Multi-disciplinary
    Lee Mac's Discipline Details
    Discipline
    Multi-disciplinary
    Details
    Custom Programming / Software Customisation
    Using
    AutoCAD 2018
    Join Date
    Aug 2008
    Location
    London, England
    Posts
    19,539
    Default
    Apply fixed_width = true to the row tile:
    Code:
    test : dialog
        : text
        : row
            fixed_width = true;
            : boxed_column
                width = 10;
                alignment = left;
                fixed_width = true;
                : text
                    label = "1.";
                : text
                    label = "2.";
                    alignment = left;
            : boxed_column
                width = 20;
                fixed_width = true;
                : text
                    label = "3.";
                    alignment = right;
                : text
                    label = "4.";
                    alignment = left;
        : row
            : edit_box
                label = "Test:";
                key = "Edit4"; //Edit1$ from lsp file
                edit_width = 150.0;
                alignment = left;
                fixed_width = true;
        ok_cancel;
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    With Mathematics there is the possibility of perfect rigour, so why settle for less?
  3. #3
    Using
    Civil 3D 2014
    Join Date
    Apr 2013
    Posts
    84
    Default
    Thank you for your help.
    I have one more question.
    How to make such formatting edit_box with label.
    Code:
    // MyEditText
    MyEditText : dialog {
      key = "Title";
      label = "";//Title$ from lsp file
      : text {
      label = "DCL test.";
      initial_focus = "Edit1";
      spacer;
      //: row {
        : column {
          width = 5.09;
          fixed_width = true;
          spacer;
        : edit_box {
        label = "BLK:";
          key = "Edit1";//Edit1$ from lsp file
          edit_width = 30.0;
          alignment = left;
          fixed_width = true;
      initial_focus = "Edit2";
      spacer;
      //: row {
        : column {
          width = 5.09;
          fixed_width = true;
          spacer;
        //  : text {
          //  key = "Prompt1";
          //  label = "";//Prompt from lsp file
        : edit_box {
        label = "Attrib:";
          key = "Edit2";//Edit1$ from lsp file
          edit_width = 30.0;
          alignment = left;
          fixed_width = true;
       initial_focus = "Edit3";
      spacer;
      //: row {
        : column {
          width = 5.09;
          fixed_width = true;
          spacer;
         // : text {
          //  key = "Prompt2";
        : edit_box {
          key = "Edit3";//Edit1$ from lsp file
          edit_width = 100.0;
          label = "Name:";
          alignment = left;
          fixed_width = true;
      spacer;
      : row {
        fixed_width = true;
        : ok_button {
          width = 10;
        : cancel_button {
          width = 10;
    }//MyEditText
    The code makes a window like in the picture below.
    How to align the edit_box to the left side like in the picture below.
  4. #4
    Luminous Being Tharwat's Avatar
    Discipline
    Mechanical
    Tharwat's Discipline Details
    Occupation
    MEP AutoCAD Draughtsman
    Discipline
    Mechanical
    Details
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    Using
    AutoCAD 2015
    Join Date
    Oct 2009
    Location
    Great Syria , Living in Abu Dhabi
    Posts
    6,179
    Default
    Quote Originally Posted by Kowal View Post
    Hi,
    Divide edit_box tile into two tiles like this:
    Code:
    : row { : text { label = "BLK:"; } : edit_box { key = "Edit1";}}
    Then add a space tile with specific width value to suit them in the alignment way you want it.
  5. #5
    Computer Details
    Operating System:
    Discipline
    Multi-disciplinary
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2018
    Join Date
    Aug 2008
    Location
    London, England
    Posts
    19,539
    Default
    There is no need for rows of separate text/edit_box tiles, simply adjust the width attribute to account for the largest label:
    Code:
    test : dialog
        spacer;
        : edit_box
            key = "edit1";
            label = "Block:";
            width = 42.0;
            edit_width = 30.0;
            fixed_width = true;
            alignment = left;
        : edit_box
            key = "edit2";
            label = "Attrib:";
            width = 42.0;
            edit_width = 30.0;
            fixed_width = true;
            alignment = left;
        : edit_box
            key = "edit3";
            label = "Name:";
            width = 112.0;
            edit_width = 100.0;
            fixed_width = true;
            alignment = left;
        ok_cancel;
    The above yields:
  6. #6
    Super Member
    Discipline
    Multi-disciplinary
    Using
    AutoCAD 2015
    Join Date
    Nov 2013
    Posts
    1,449
    Default
    I've followed Tharwat's advice and ended up with some nice results:
    Code:
    test1 : dialog
    { label = "EB Alignment test"; spacer_1;
      : column
      { alignment = centered; fixed_width = true; children_alignment = centered;
        : row { children_alignment = right; : text { label = "BLK:"; fixed_width = true; } : edit_box { key = "eb1"; fixed_width = true; }}
        : row { children_alignment = right; : text { label = "Attrib:"; fixed_width = true; } : edit_box { key = "eb2"; fixed_width = true; }}
        : row { children_alignment = right; : text { label = "Name:"; fixed_width = true; } : edit_box { key = "eb3"; fixed_width = true; }}
      spacer_1; ok_only; spacer_1;
    Code:
    test2 : dialog
      : column
        : row { children_alignment = right; : text { label = "Name (First and Second):"; fixed_width = true; } : edit_box { key = "eb1"; fixed_width = true; }}
        : row { children_alignment = right; : text { label = "Age:"; fixed_width = true; } : edit_box { key = "eb2"; fixed_width = true; }}
        : row { children_alignment = right; : text { label = "Address:"; fixed_width = true; } : edit_box { key = "eb3"; fixed_width = true; }}
        : row { children_alignment = right; : text { label = "Email:"; fixed_width = true; } : edit_box { key = "eb4"; fixed_width = true; }}
    They reminded me about his nice dialogs in his HVAC/Piping programs.
    However Lee's suggestion seems more suitable for the OP's dialog problem.
  7. #7
    Discipline
    Mechanical
    Occupation
    Discipline
    Mechanical
    Details
    Using
    AutoCAD 2015
    Join Date
    Oct 2009
    Location
    Posts
    6,179
    Default
    Good job Grrr and thanks for the nice words.
Similar Threads
  1. add comment/remark column to alignment table
    By sandiegophil in forum Civil 3D & LDD
    Last Post: 3rd Mar 2016, 08:16 pm
  2. Replies: 0
    Last Post: 15th Jan 2014, 01:43 pm
  3. Replies: 2
    Last Post: 26th Feb 2013, 05:35 pm
  4. Replies: 6
    Last Post: 11th Sep 2012, 08:20 pm
  5. column Alignment -Pls Help
    By muthu123 in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th May 2010, 10:16 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
