DCL alignment column
Kowal
I am trying to format the DCL window.
  : text {
 label = "Test DCL.";
 alignment = centered;
 : row {
 : boxed_column {
 width = 10;
 alignment = left;
 fixed_width = true;
 : text {
 label = "1.";
 : text {
 label = "2.";
 alignment = left;
   : boxed_column {
   width = 20;
 fixed_width = true;
 : text {
 label = "3.";
 alignment = right;
 : text {
 label = "4.";
 alignment = left;
 : row {
     : edit_box {
   label = "Test:";
     key = "Edit4";//Edit1$ from lsp file
     edit_width = 150.0;
     alignment = left;
     fixed_width = true;
The window looks like this:
How to move the column to the left does not change its width.
As in the picture below.
Apply fixed_width = true to the row tile:
test : dialog
   : text
   : row
       [color=red]fixed_width = true;[/color]
       : boxed_column
           width = 10;
           alignment = left;
           fixed_width = true;
           : text
               label = "1.";
           : text
               label = "2.";
               alignment = left;
       : boxed_column
           width = 20;
           fixed_width = true;
           : text
               label = "3.";
               alignment = right;
           : text
               label = "4.";
               alignment = left;
   : row
       : edit_box
           label = "Test:";
           key = "Edit4"; //Edit1$ from lsp file
           edit_width = 150.0;
           alignment = left;
           fixed_width = true;
   ok_cancel;
Thank you for your help.
I have one more question.
How to make such formatting edit_box with label.
// MyEditText
MyEditText : dialog {
 key = "Title";
 label = "";//Title$ from lsp file
 : text {
 label = "DCL test.";
 initial_focus = "Edit1";
 spacer;
 //: row {
   : column {
     width = 5.09;
     fixed_width = true;
     spacer;
   : edit_box {
   label = "BLK:";
     key = "Edit1";//Edit1$ from lsp file
     edit_width = 30.0;
     alignment = left;
     fixed_width = true;
 initial_focus = "Edit2";
 spacer;
 //: row {
   : column {
     width = 5.09;
     fixed_width = true;
     spacer;
   //  : text {
     //  key = "Prompt1";
     //  label = "";//Prompt from lsp file
   : edit_box {
   label = "Attrib:";
     key = "Edit2";//Edit1$ from lsp file
     edit_width = 30.0;
     alignment = left;
     fixed_width = true;
  initial_focus = "Edit3";
 spacer;
 //: row {
   : column {
     width = 5.09;
     fixed_width = true;
     spacer;
    // : text {
     //  key = "Prompt2";
   : edit_box {
     key = "Edit3";//Edit1$ from lsp file
     edit_width = 100.0;
     label = "Name:";
     alignment = left;
     fixed_width = true;
 spacer;
 : row {
   fixed_width = true;
   : ok_button {
     width = 10;
   : cancel_button {
     width = 10;
}//MyEditText
The code makes a window like in the picture below.
How to align the edit_box to the left side like in the picture below.
Hi,
Divide edit_box tile into two tiles like this:
: row { : text { label = "BLK:"; } : edit_box { key = "Edit1";}}
Then add a space tile with specific width value to suit them in the alignment way you want it.
There is no need for rows of separate text/edit_box tiles, simply adjust the width attribute to account for the largest label:
test : dialog
   spacer;
   : edit_box
       key = "edit1";
       label = "Block:";
       width = 42.0;
       edit_width = 30.0;
       fixed_width = true;
       alignment = left;
   : edit_box
       key = "edit2";
       label = "Attrib:";
       width = 42.0;
       edit_width = 30.0;
       fixed_width = true;
       alignment = left;
   : edit_box
       key = "edit3";
       label = "Name:";
       width = 112.0;
       edit_width = 100.0;
       fixed_width = true;
       alignment = left;
   ok_cancel;
The above yields:
I've followed Tharwat's advice and ended up with some nice results:
test1 : dialog
{ label = "EB Alignment test"; spacer_1;
 : column
 { alignment = centered; fixed_width = true; children_alignment = centered;
   : row { children_alignment = right; : text { label = "BLK:"; fixed_width = true; } : edit_box { key = "eb1"; fixed_width = true; }}
   : row { children_alignment = right; : text { label = "Attrib:"; fixed_width = true; } : edit_box { key = "eb2"; fixed_width = true; }}
   : row { children_alignment = right; : text { label = "Name:"; fixed_width = true; } : edit_box { key = "eb3"; fixed_width = true; }}
 spacer_1; ok_only; spacer_1;
test2 : dialog
 : column
   : row { children_alignment = right; : text { label = "Name (First and Second):"; fixed_width = true; } : edit_box { key = "eb1"; fixed_width = true; }}
   : row { children_alignment = right; : text { label = "Age:"; fixed_width = true; } : edit_box { key = "eb2"; fixed_width = true; }}
   : row { children_alignment = right; : text { label = "Address:"; fixed_width = true; } : edit_box { key = "eb3"; fixed_width = true; }}
   : row { children_alignment = right; : text { label = "Email:"; fixed_width = true; } : edit_box { key = "eb4"; fixed_width = true; }}
They reminded me about his nice dialogs in his HVAC/Piping programs. 8)
However Lee's suggestion seems more suitable for the OP's dialog problem.
