Results 1 to 6 of 6
    Forum Newbie
    HVAC
    AutoCAD 2015
    Sep 2017
    4
    Default Incremental Attribute using AutoLisp
    Hello,
    I am new to AutoLISP world. I am trying to write a code which will edit attribute in incremental numbering with each click on attribute. The easiest way command for it is "ATTIPEDIT".
    But I failed use ATTIPEDIT in LISP. Pls help to run this code:
    Code:
    (defun c:DTAG ()
     (princ "\n AUTOMATIC ATTRIBUTE SEQUENTIAL NUMBERING")
     (setq no (getint "\n Enter Starting Number : "))
     (setq pt T)
     (while pt
      (setq notxt (itoa no))
      (setq pt (getpoint (strcat "\n Select Attribute to be changed ( "notxt" ) < exit > : ")))
      (if pt
       (command "_.ATTIPEDIT" pt notxt)
       (setq no (+ no 1))
      (princ "\n Routine terminated normally by User")
    (setvar "CMDECHO" ocmd)
    (setq *error* olderr) ;;Restore old error handler
    PFA ACAD file to test. Try putting incremental numbers in place of "0".
    Senior Member satishrajdev's Avatar
    satishrajdev's Computer Details
    Windows 7 - 64bit
    DELL
    8 GB
    500 GB
    DELL
    Surveying
    satishrajdev's Discipline Details
    CAD Engineer
    Surveying
    Design Survey Utilities (i.e. Bathymetry & Geophysical Survey) Design of Survey Planning. Preparation of Alignment Sheets. Programming in AutoCAD.
    AutoCAD 2014
    Apr 2012
    Aamchi Mumbai, India
    442
    Alternate Method :-
    Code:
    (while (setq pt	(nentsel (strcat "\n Select Attribute to be changed ( "
    				 (itoa no)
    				 " ) < exit > : "
      (setq e (entget (car pt)))
      (entmod (subst (cons 1 (itoa no)) (assoc 1 e) e))
      (setq no (1+ no))
    Best Regards,
    Satish Rajdev
    If you ride like there is no tomorrow... Don't worry, there won't be !!!!
    www.facebook.com/satish.rajdev
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,960
    Please read the Code Posting Guidelines and have your Code to be included in Code Tags.[CODE]Your Code Here[/CODE] =
    Code:
    Your Code Here
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,175
    Satishrajdev you confused me for a moment I thought the same use nentsel then read your post, first glance Pt so it was looking for a xy point thats strange then realised its the variable name. Just me but 99% of the code here would use Pt Pt1 etc for xyz points. I am not being critical but what I am suggesting is that it would be better to use something like ent att etc as a variable name, particuarly for what appears to be a newcomer to the world of programming.
  5. #5
    Windows 7 - 64bit
    DELL
    8 GB
    500 GB
    DELL
    Surveying
    CAD Engineer
    Surveying
    AutoCAD 2014
    Apr 2012
    442
    Bigal, I know its standard practice what you suggested but I was just trying to simply OP's code and that's why I didn't change his any variable so that as newbie he can understand and learn where to make changes in code accordingly. I use the same standard practice which you mentioned above.
    Best Regards,
    Satish Rajdev
  6. #6
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,175
    No worries, reminds of when I started learning programming using fortran punch cards.
  1. Incremental Attribute
    By satishrajdev in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Feb 2016, 02:34 pm
  2. Incremental numbering attribute block
    By crowscratch in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Jun 2014, 03:33 pm
  3. Incremental attribute edit by like values
    By scottE in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Jun 2009, 02:13 pm
  4. Assign block attribute value to an AutoLISP variable?
    By cliath in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Mar 2006, 01:33 am
  5. Linking text box to attribute value (AutoLISP, VBA or...?)
    By scootermac in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Sep 2005, 12:35 pm
Tags for this Thread
