Results 1 to 7 of 7
Thread: X-Y Dimensions
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    34
    Default X-Y Dimensions
    Is there a way to dimension the x-y lengths between two points at the same time without have to do a linear dimension each time?
    I don't wan't coordinates. I am looking for lengths.
    Maybe a lisp or a macro?
    Thanks
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,154
    Simplest way is a dimension style you can turn off lots of stuff so could just have a style which is the arrows but it would use the dim align command but a little lisp would fix that.
    Good one to have a go at yourself. In words pick pt1, pick pt2, command dim align pt1 pt2 all done
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    34
    If only I knew how to write lisp codes.
    Full Member
    Dahzee's Computer Details
    64bit Windows 7 pro
    24" x 2
    See details...
    Dahzee's Discipline Details
    Cardboard Engineer
    See details below.
    Design & Prototyping of Cardboard Packaging and Point of Sale.
    not applicable
    Sep 2010
    Hampshire (England)
    30
    Robwell,
    This will dimension x and y of a selection, not sure if it is what you need.
    Tharwat kindly wrote this so make sure you don't remove his name.
    Code:
    (defun c:kk (/ s i l r l1 r1 lx ly rx ry a b c d p1 p2 p3)
      ;;    Tharwat 28. Nov. 2013         ;;
      (if (setq s (ssget '((-4 . "<NOT")
                           (-4 . "<OR")
                           (0 . "XLINE")
                           (0 . "RAY")
                           (0 . "*DIMENSION")
                           (-4 . "OR>")
                           (-4 . "NOT>")
          (repeat (setq i (sslength s))
            (vla-GetBoundingBox
              (vlax-ename->vla-object (ssname s (setq i (1- i))))
              'l
              'r
            (setq l1 (vlax-safearray->list l)
                  r1 (vlax-safearray->list r)
                  lx (cons (car l1) lx)
                  ly (cons (cadr l1) ly)
                  rx (cons (car r1) rx)
                  ry (cons (cadr r1) ry)
          (setq a  (apply 'min lx)
                b  (apply 'min ly)
                c  (apply 'max rx)
                d  (apply 'max ry)
                p1 (list c d)
                p2 (list a d)
                p3 (list c b)
          (command "._dimlinear"
                   "_none"
                   p1
                   "_none"
                   p2
                   "_none"
                   (polar p1 (* pi 0.5) (/ (distance p1 p2) 10.))
                   "_none"
                   p1
                   "_none"
                   p3
                   "_none"
                   (polar p1 0. (/ (distance p1 p3) 10.))
    (vl-load-com)
  5. #5
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    34
    This works perfectly. I was able to manipulate a couple numbers to make the offset a little further out. The only thing I wish I knew how to do would be to put the dims on the opposite sides in which they are placed with this lisp. I can still definitely use it though. Thank you.
    If anyone knows how to manipulate the location placement of the dims, that would be awesome.
    Thanks again, Dahzee.
  6. #6
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,179
    Quote Originally Posted by robwell View Post
    If I understand what you want and what the code says, you can move the origin to the other side of the selection box. In other words, the line
    p1 (list c d)
    becomes
    p1 (list a b)
    breaking AutoCAD on a regular basis since 1991
  7. #7
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    34
    That's the right direction CyberAngel, thanks. It doesn't place them exactly as I like, so I will work with that to find the right placement.
  1. Aligned Dimensions vs Rotated Dimensions
    By Tyke in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 10th Oct 2013, 01:51 pm
  2. Dimensions with arc?
    By tennis4you in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Jun 2011, 06:29 pm
  3. Drive feature dimensions with sketch dimensions?
    By Hickoz_bro in forum SolidWorks
    Last Post: 15th May 2011, 01:41 am
  4. Dimensions
    By donbosco in forum AutoCAD Beginners' Area
    Last Post: 22nd Oct 2010, 08:11 pm
  5. dimensions fly away
    By the ber in forum AutoCAD Beginners' Area
    Last Post: 23rd Mar 2008, 09:47 am
