+ Reply to Thread
Results 1 to 9 of 9
  1. #1
    Junior Member
    Discipline
    Electrical
    Using
    AutoCAD 2018
    Join Date
    Jan 2018
    Posts
    11
    Default Select blocks by attribute TAG
    Hello...I find a lot of solution for select blocks by an attribute values, but I did not find any solution for select all blocks in a file that have an attributes with the same tag.
    For example I want to select all the blocks that have the attribute tag "SIGLA"...I did not find a way by using normal autocad procedures or commands...
    Regards
  2. #2
    Super Member
    Computer Details
    ronjonp's Computer Details
    Operating System:
    Windows 10
    Using
    AutoCAD 2018
    Join Date
    Apr 2009
    Location
    Colorado
    Posts
    670
    Default
    The FIND command can create a selection set of objects with the same value.
  3. #3
    Super Member
    Discipline
    Multi-disciplinary
    Using
    AutoCAD 2015
    Join Date
    Nov 2013
    Posts
    1,280
    Default
    This should work. Sorry for the coding style (I was bored) :
    Code:
    (defun C:test ( / tmp )
      (if
        (setq tmp
          ((lambda (every L / tmp) (if (apply '= (mapcar 'length (list L (setq tmp (every L))))) tmp))
            (lambda (L / tmp) (if (setq tmp (eval (car L))) (cons tmp (every (cdr L)))))
            '( (if (not vlax-get-acad-object) (alert "(vl-load-com)") t)
              (ssget "_X" '((0 . "INSERT")(66 . 1)))
              (car (nentsel "\nPick attribute: "))
              ''(87 97 116 99 104 97 32 108 111 111 107 105 110 103 32 102 111 114 63)
        (apply
          '(lambda ( c a b d / enx v nSS i e o nm n atts nmL )
            (and a b
              (member '(0 . "ATTRIB") (setq enx (entget b)))
              (setq v (mapcar '(lambda (x) (cdr (assoc x enx))) '(2 1)))
              (setq nSS (ssadd))
              (repeat (setq i (sslength a))
                (or
                  (and
                    (setq nm (vlax-get (setq o (vlax-ename->vla-object (setq e (ssname a (setq i (1- i)))))) 'EffectiveName))
                    (setq atts (vlax-invoke o 'GetAttributes))
                    nmL (setq n (cdr (assoc nm nmL)))
                    ( (lambda (x) (equal v (mapcar (function vlax-get) (list x x) '(TagString TextString)) 1e-3)) (nth n atts) )
                    (ssadd e nSS)
                  ); and
                  (and
                    (setq n -1)
                    (vl-some (function (lambda (x) (setq n (1+ n)) (if (equal v (mapcar (function (lambda (xx) (vlax-get x xx))) '(TagString TextString)) 1e-3) n))) atts)
                    (setq nmL (cons (cons nm n) nmL))
                    (ssadd e nSS)
                  ); and
                ); or
              ); repeat
            ); and
            (and nSS (/= 0 (sslength nSS)) (sssetfirst nil nSS))
          ); lambda
          tmp
    (vl-load-com) (princ)
  4. #4
    Quantum Mechanic Lee Mac's Avatar
    Computer Details
    Lee Mac's Computer Details
    Operating System:
    Windows 7 Ultimate (32-bit)
    Discipline
    Multi-disciplinary
    Lee Mac's Discipline Details
    Discipline
    Multi-disciplinary
    Details
    Custom Programming / Software Customisation
    Using
    AutoCAD 2013
    Join Date
    Aug 2008
    Location
    London, England
    Posts
    19,456
    Default
    I don't think the code need be quite so complex - here is a simple example:
    Code:
    (defun c:selbytag ( / a e i n s x )
        (setq n "SIGLA")
        (if (setq s (ssget "_X" '((0 . "INSERT") (66 . 1))))
            (repeat (setq i (sslength s))
                (setq i (1- i)
                      e (ssname  s i)
                      a (entnext e)
                      x (entget  a)
                (while (and (= "ATTRIB" (cdr (assoc 0 x))) (/= n (strcase (cdr (assoc 2 x)))))
                    (setq a (entnext a)
                          x (entget  a)
                (or (= "ATTRIB" (cdr (assoc 0 x))) (ssdel e s))
        (sssetfirst nil s) (princ)
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    With Mathematics there is the possibility of perfect rigour, so why settle for less?
  5. #5
    Quantum Mechanic
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,151
    Default
    Re lee's code, for a block that you can see on screen use this, non hard coded answer.
    Code:
    (setq n (cdr (assoc 2 (entget (car (nentsel "pick attribute"))))))
  6. #6
    Super Member
    Computer Details
    Operating System:
    Windows 10
    Using
    AutoCAD 2018
    Join Date
    Apr 2009
    Location
    Colorado
    Posts
    670
    Default
    Here's a VL variant:
    Code:
    (defun c:foo (/ s tag)
      (setq tag "SIGLA")
      (if (setq s (ssget '((0 . "INSERT") (66 . 1))))
        (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
          (and (null (vl-some '(lambda (x) (eq (vla-get-tagstring x) (strcase tag)))
    			  (vlax-invoke (vlax-ename->vla-object e) 'getattributes)
    	   (ssdel e s)
      (sssetfirst nil s)
    (vl-load-com)
  7. #7
    Junior Member
    Discipline
    Electrical
    Using
    AutoCAD 2018
    Join Date
    Jan 2018
    Posts
    11
    Default
    thank you all! tomorrow I'll try them all...
    In the meantime, looking with google, I found other possible solutions...I read what "Information for new members" says about link so, for completeness, I'll pass you the link and it will be ok you'll read what i have found.
    I write to you as soon as possible!
  8. #8
    Junior Member
    Discipline
    Electrical
    Using
    AutoCAD 2018
    Join Date
    Jan 2018
    Posts
    11
    Default
    Hello to everyone! I tried the various lisp and these are my conclusions...I apologize if they are inaccurate but it was a full week, I did not have time and I report the "immediate result"...:
    1) the Grrr's lisp stopped after the pick of the attribute (I'll try it again)...but I like the idea of select by click an attribute!
    2) the ronjob's lisp is ok and I like that it works by a selection area
    3) selbytag is ok and it works also with frozen layer that it is very useful for me...at the moment I prefer this lisp.
    Maybe to exercise I'll try to write a lisp that includes all three...
    The other solution I have found in internet are these:
    https://forums.autodesk.com/t5/autoc...s/td-p/4791745 (very interesting)
    https://forums.autodesk.com/t5/visua...g/td-p/7377964
    the next step is it to extrapolate the values contained in the chosen attribute for count them!
    I tried the express command attext but it generates useless txt file...I will try to find some method that generate file .csv (I hope it exists).
    I love Lee Mac lisp like Count Attributes Value or Block Counter because they organize the data in tables or csv files, but I need to work only with the values of the tag attribute I choose for the selection.
    I thank you again and I greet you
  9. #9
    Super Member
    Discipline
    Multi-disciplinary
    Using
    AutoCAD 2015
    Join Date
    Nov 2013
    Posts
    1,280
    Default
    Quote Originally Posted by itacad View Post
    Doh! Fixed..
Similar Threads
  1. Replies: 8
    Last Post: 2nd Apr 2017, 08:05 pm
  2. [NEVERMIND] Select blocks by specific attribute value
    By Gotrekk in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Apr 2016, 05:03 pm
  3. How to select an attribute?
    By pkl in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Nov 2015, 06:52 pm
  4. Cant select attribute
    By Ski_Me in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Jul 2015, 07:22 pm
  5. Select Blocks by Name & Attribute Property
    By churchill in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Nov 2013, 01:34 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
