Results 1 to 2 of 2
    Forum Newbie
    Construction
    AutoCAD 2015
    Feb 2018
    1
    Default Dxf default to "save objects:
    Hi Guys, I'm using autocad 2015. I save a lot of dxf files to convert to G-Code. When saving a dxf, is there a way to automatically turn on the "select objects" option in the "save as dialogue box"
    I must turn it on 30 times a day
    Thanks
    the cleric
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,084
    You could make a Script or maybe a Button Macro, if you want to do those, set FILEDIA=0, then you will get a commandline version of SAVEAS (same as DXFOUT), just look at the commanline for the options you want.
    You might look at using a LISP.
  1. error "cannot save one or more objects...." on dropbox
    By designerstuart in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 11th Aug 2015, 01:58 pm
  2. Change default "Save As" folder
    By laqa in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 1st Apr 2015, 05:23 pm
  3. "save" in the file "pull down menu" not working
    By kfarrar in forum Civil 3D & LDD
    Last Post: 25th Dec 2013, 10:22 am
  4. Replies: 0
    Last Post: 15th Nov 2010, 08:30 am
  5. Can I make "Select boundary objects" default hatch action? (2011)
    By bodejodel in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Sep 2010, 10:09 am
