Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Full Member
    Tomislav's Computer Details
    win7 x64
    Asrock Extreme 3.0
    AMD fx-8350
    8
    R9 270x
    SSD 128GB
    SSHD 1TB
    LG 23" IPS
    Surveying
    Tomislav's Discipline Details
    surveyor
    Surveying
    civil surveying
    Map 3D 2014
    Nov 2012
    Croatia
    46
    Default Lisp routines don't work in deeper folders
    Hello everybody.
    I don't know am I posting to the right place but maybe someone can help.
    The problem is that my lisp routines won't work on files that are saved more than two levels of nested folders (C:/something/something/something/file.dwg) and I can't figure out why.I get the message that file is nil. I have win10 x64 and tried with few versions of CAD. Any suggestions?
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    759
    Well , without a lisp that's a tough one to answer ...
    Standard pitfalls are correct use of escape characters \\ vs / and \" for " , spaces in folder paths. Use something like
    Code:
     (if (setq fn (findfile your-dwg-name)) (open_fn_and_do_your_stuff) ;|else|;(princ "drawing not found"))
    gr. Rlx
    Full Member
    win7 x64
    Asrock Extreme 3.0
    AMD fx-8350
    8
    R9 270x
    SSD 128GB
    SSHD 1TB
    LG 23" IPS
    Surveying
    surveyor
    Surveying
    civil surveying
    Map 3D 2014
    Nov 2012
    Croatia
    46
    I can put in one lisp but it's all of them using file manipulation, and they have worked before on my old system, and work in my office so I think it's not about them but maybe some cad or system settings.
    I noticed something curious, when they are loaded as part of one big .vlx file with every drawing, cad writes"******** no system variable has been changed ***********" (or something like this)
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,175
    Like Rlx
    Code:
    (C:\\something\\something\\something\\file.dwg)
    A different problem
    Code:
    (C:/something/something/something/file dwg1.dwg)
    It will fail at the filespacedwg1 the space in the name causes problems
    Again like Rlx post the bit of code.
  5. #5
    Full Member
    win7 x64
    Asrock Extreme 3.0
    AMD fx-8350
    8
    R9 270x
    SSD 128GB
    SSHD 1TB
    LG 23" IPS
    Surveying
    surveyor
    Surveying
    civil surveying
    Map 3D 2014
    Nov 2012
    Croatia
    46
    Code:
    (defun c:lp (/ f a numt doc_path txt decimals name loop)
      (defun *error* (msg)
        (if(or(= msg "quit / exit abort")
    	  (= msg "bad argument type: lentityp nil")
    	  (= msg "bad argument type: numberp: nil")
          (princ "")
          (princ msg)
        (close f)
      (setvar "cmdecho" 0)
      (command "dimzin" 0)
      (setvar "cmdecho" 1)
      (setq txt "")
      (initget 0 "N W")
      (or
        (setq name
    	   (getkword
    	     "\nDo you wish to list coords with name or without [ <Name> / Without ] "))
        (setq name "N")
      (initget 0 "0 1 2 3 4")
      (or
        (setq decimals(getkword"\nEnter number of decimals  [ 0/1/2/3/4 ] <3> : "))
        (setq decimals "3")
      (setq decimals (atoi decimals))
      (setq doc_path(getvar 'DWGPREFIX))
      (setq doc_path (vl-string-translate "/" "\\" doc_path))
      (setq f (open (getfiled "Text File" doc_path "txt" 5) "a"))
      (setq loop T)
      (while loop
        (if (= name "N")
    	(if(wcmatch
    	     (cdr
    	       (assoc 0
    		      (setq numt (ENTGET (CAR (ENTSEL "\nSelect point number: "))))
    	     "ATTRIB,MTEXT,TEXT"
    	    (setq a (getpoint "\nSelect point: "))
    	    (if(=(cdr(assoc 0 numt))"MTEXT")
    		(GetTextFromMText numt)
    		(princ txt f)
    		(princ"\n")
    	      (princ (cdr (assoc 1 numt)) f)
    	    (princ "," f)
    	    (princ (rtos (car a) 2 decimals) f)
    	    (princ "," f)
    	    (princ (rtos (cadr a) 2 decimals) f)
    	    (princ "," f)
    	    (princ (rtos (caddr a) 2 decimals) f)
    	    (princ "," f)
    	    (princ "\n" f)
    	    (close f)
    	    (quit)
        (if (= name "W")
    	(princ "," f)
    	(princ "," f)
    	(princ "," f)
    	(princ "\n" f)
      (close f)
      (quit)
    (princ
      "\nList points...by TOMISLAV VARGEK...Osijek,Croatia...\n...Type LP to initiate..."
    (defun GetTextFromMText (numt / posto_pos ima)
      (setq txt (cdr (assoc 1 numt)))			 	;vadim tekst
      (setq txt(vl-string-right-trim " } " txt))		       ;oduzimam desnu } i razmak
      (setq txt(substr txt (+(vl-string-search ";" txt)2)))        ;oduzimam sve do prvog ;
      (if (=(vl-string-search ";" txt (-(strlen txt)1))(-(strlen txt)1)); ako je ; na kraju
        (setq txt(vl-string-right-trim "; " txt))			;oduzimam desno sve do ;
      (if (=(vl-string-search "{" txt)0)	;ako je ostala na prvom mjestu { vadim sve od
        (setq txt(substr txt(vl-string-search ";" txt))); prvog ; do kraja
      (if (>(vl-string-search "{" txt)0)	                    ;ako je ostala negdje { vadim sve od nje do ;
        (setq txt(strcat(substr txt 1 (vl-string-search "{" txt)); i spajam s ostalim
    	       (substr txt(+(vl-string-search ";" txt)2))
      (setq txt(vl-string-subst "" "\\S" txt))
      (setq ima T)
      (while ima
        (if (>(setq posto_pos(vl-string-search "%%" txt))0)
          (setq txt(strcat(substr txt 1 posto_pos)(substr txt (+ posto_pos 4))))
          (setq ima nil)
  6. #6
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    759
    Quote Originally Posted by Tomislav View Post
    There may be differences in cad versions , like command vs command-s and on some systems there may be a reactor at work in the background?
  7. #7
    Full Member
    win7 x64
    Asrock Extreme 3.0
    AMD fx-8350
    8
    R9 270x
    SSD 128GB
    SSHD 1TB
    LG 23" IPS
    Surveying
    surveyor
    Surveying
    civil surveying
    Map 3D 2014
    Nov 2012
    Croatia
    46
    I've tried a couple of CAD versions in which they work at my office...I don't know what is this reactor
  8. #8
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    759
    reactors are like little gremlins that work in the background and can react on certain commands. But I see you have added some code. Maybe the answer lies in the code , I or Bigal will have a look. First have a meeting shortly...
  9. #9
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    759
    well I can't find what the path would matter for your app to function so I can't reproduce your problem. Did some rlx-pimping to test it on my own system. Just want to say that I strongly advise not to use (quit) , its like putting out the light with a brick or hitting your mother-in-law with a truck when a baseball bat is sufficient enough...
    Code:
    (defun c:lp  (/ f a inp numt doc_path txt decimals name)
        (if (or (= msg "quit / exit abort") (= msg "bad argument type: lentityp nil") (= msg "bad argument type: numberp: nil"))
          (princ "") (princ msg)) (if f (close f)))
      (setvar "cmdecho" 0) (command "dimzin" 0)(setvar "cmdecho" 1) (setq txt "")
      (initget 0 "N W")
      (or (setq name (getkword "\nDo you wish to list coords with name or without [ <Name> / Without ] "))(setq name "N"))
      (or (setq decimals (getkword "\nEnter number of decimals  [ 0/1/2/3/4 ] <3> : "))(setq decimals "3"))
      (setq decimals (atoi decimals) doc_path (vl-string-translate "/" "\\" (getvar 'DWGPREFIX)))
      (if (setq f (open (getfiled "Text File" doc_path "txt" 5) "a"))
        (while (setq inp (entsel "\nSelect point number: "))
          (cond
     ((and (= name "N") (member (cdr (assoc 0 (setq numt (entget (car inp))))) '("ATTRIB" "MTEXT" "TEXT")))
             ;(if (= (cdr (assoc 0 numt)) "MTEXT") (progn (GetTextFromMText numt)(princ txt f)(princ "\n"))(princ (cdr (assoc 1 numt)) f))
        (princ (LM:UnFormat (cdr (assoc 1 numt)) nil) f) (princ (cdr (assoc 1 numt)) f))
      (mapcar
        '(lambda (x) (princ x f))
        (list "," (rtos (car a) 2 decimals) "," (rtos (cadr a) 2 decimals) "," (rtos (caddr a) 2 decimals) "\n")
             ;(princ "," f) (princ (rtos (car a) 2 decimals) f)  (princ "," f) (princ (rtos (cadr a) 2 decimals) f)
             ;(princ "," f) (princ (rtos (caddr a) 2 decimals) f) (princ "," f)(princ "\n" f)
            ((= name "W")
             (princ (rtos (car a) 2 decimals) f)(princ "," f)(princ (rtos (cadr a) 2 decimals) f)(princ "," f)
             (princ (rtos (caddr a) 2 decimals) f)(princ "," f)(princ "\n" f))
      (if f (close f))
    (princ "\nList points...by TOMISLAV VARGEK...Osijek,Croatia...\n...Type LP to initiate...")
      (setq txt (vl-string-right-trim " } " txt))
      (setq txt (substr txt (+ (vl-string-search ";" txt) 2)))
      (if (= (vl-string-search ";" txt (- (strlen txt) 1))
      (- (strlen txt) 1)
      )    ; ako je ; na kraju
        (setq txt (vl-string-right-trim "; " txt)) ;oduzimam desno sve do ;
      (if (= (vl-string-search "{" txt) 0) ;ako je ostala na prvom mjestu { vadim sve od
        (setq txt (substr txt (vl-string-search ";" txt)))
         ; prvog ; do kraja
      (if (> (vl-string-search "{" txt) 0) ;ako je ostala negdje { vadim sve od nje do ;
        (setq txt (strcat (substr txt 1 (vl-string-search "{" txt))
      (setq txt (vl-string-subst "" "\\S" txt))
      (setq ima T)
      (while ima
        (if (> (setq posto_pos (vl-string-search "%%" txt)) 0)
          (setq txt (strcat (substr txt 1 posto_pos)(substr txt (+ posto_pos 4))))
          (setq ima nil)
    ;;-------------------=={ UnFormat String }==------------------;;
    ;;  Returns a string with all MText formatting codes removed. ;;
    ;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
    ;;  Arguments:                                                ;;
    ;;  str - String to Process                                   ;;
    ;;  mtx - MText Flag (T if string is for use in MText)        ;;
    ;;  Returns:  String with formatting codes removed            ;;
    (defun LM:UnFormat ( str mtx / _replace rx )
      (defun _replace ( new old str )(vlax-put-property rx 'pattern old)(vlax-invoke rx 'replace str new))
      (if (setq rx (vlax-get-or-create-object "VBScript.RegExp"))
          (setq str
          (vl-catch-all-apply
            (function
       (lambda ( )
         (vlax-put-property rx 'global actrue)(vlax-put-property rx 'multiline actrue)
         (vlax-put-property rx 'ignorecase acfalse)
         (foreach pair '( ("\032"    . "\\\\\\\\")
                                        (" "       . "\\\\P|\\n|\\t")
                                        ("$1"      . "\\\\(\\\\[ACcFfHLlOopQTW])|\\\\[ACcFfHLlOopQTW][^\\\\;]*;|\\\\[ACcFfHLlOopQTW]")
                                        ("$1$2/$3" . "([^\\\\])\\\\S([^;]*)[/#\\^]([^;]*);")
                                        ("$1$2"    . "\\\\(\\\\S)|[\\\\](})|}")
                                        ("$1"      . "[\\\\]({)|{"))
           (setq str (_replace (car pair) (cdr pair) str)))
         (if mtx
           (_replace "\\\\" "\032" (_replace "\\$1$2$3" "(\\\\[ACcFfHLlOoPpQSTW])|({)|(})" str))
           (_replace "\\"   "\032" str))))))  (vlax-release-object rx)(if (null (vl-catch-all-error-p str)) str)
    gr. Rlx
  10. #10
    Full Member
    win7 x64
    Asrock Extreme 3.0
    AMD fx-8350
    8
    R9 270x
    SSD 128GB
    SSHD 1TB
    LG 23" IPS
    Surveying
    surveyor
    Surveying
    civil surveying
    Map 3D 2014
    Nov 2012
    Croatia
    46
    Quote Originally Posted by rlx View Post
    gr. Rlx
    good one
    ...and a nice mtext function..
  1. Lisp to create numbered folders based on selection
    By benhubel in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Mar 2016, 08:23 pm
  2. Autocad 13 for Mac - lisp routines won't work
    By Cesarman in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Jun 2013, 08:43 pm
  3. Replies: 3
    Last Post: 10th Aug 2010, 04:39 am
  4. LISP routines
    By Jflomofo01 in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Apr 2010, 02:47 pm
  5. Looking for 2 lisp routines
    By Annabee in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Aug 2007, 03:35 am
